June 28, 2019, 05:49 |
Disabling "Using #calcEntry" lines to stdout
Mike Worth
Rep Power: 7 |
I've got a model that I'm using to understand the impact of varying a load of different parameters on fluid washout. To make configuring all of the different parameters easier, I've created one file that calculates all of these things which is then included into various other files (controlDict, 0/U, blockMeshDict etc.).
This all seems to be working well, but because I've got a load of calculated values included in lots of places, whenever I do anything my screen is filled with lines notifying me about the calculated entries. Even simple things like foamListTimes feel the need to report all of this: Code:
mike@openfoam:~/OpenFOAM/mike-6/run/washout$ foamListTimes Using #calcEntry at line 27 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_9c3d255734d68e84b3d2147c3ea3c0131c2914cf.so" Using #calcEntry at line 28 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_1e71de4822e388b4b7969d670e158a1deb92615c.so" Using #calcEntry at line 29 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_3b80805675883eee352fc1111da03e7ae20bbcae.so" Using #calcEntry at line 30 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #calcEntry at line 33 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_65492a0c28c544e8d59fd9ff5a93d8e8d207133d.so" Using #calcEntry at line 34 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba04874e6245ae3983504503dc1db3d08765667d.so" Using #calcEntry at line 35 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_0dbaa36da7a87f36af130142861519e4b7d5b3e2.so" Using #calcEntry at line 36 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #calcEntry at line 37 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_8a98a56425548bc274062329e1b53dd5a2f0aa56.so" Using #calcEntry at line 38 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_8f25ad80897f83b899e999f21607023c9a7a4094.so" Using #calcEntry at line 39 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_32ad8860d45ea127e4414d51bc27dd87043376bd.so" Using #calcEntry at line 40 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_43497ac750afc4537375d9042519fad5df86842d.so" Using #calcEntry at line 41 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_4bdff43243e6956e09e2edb7cc8f73befc058af5.so" Using #calcEntry at line 42 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_3e2bddd8f36bcd50c7ccd0b11affa3041e0cb6b9.so" Using #calcEntry at line 44 in file "/home/mike/OpenFOAM/mike-6/run/washout/system/controlDict" Using #codeStream with "/home/mike/OpenFOAM/mike-6/run/washout/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_cb0801c86de86901ae335151d298b97062c34cfe.so" Many thanks, Mike |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 172 | December 6, 2024 07:20 |
[DesignModeler] Need to create construction lines to plot data along them in cfd-post | Soheyl.ysf | ANSYS Meshing & Geometry | 0 | April 29, 2014 03:42 |
Plotting Residuals | ata | OpenFOAM | 12 | July 8, 2011 03:50 |
