June 27, 2019, 05:29 |
Tabular heat source in CHT multiregion OF5x
Hi everyone,
I using working with CHT multiregion and using of5x. I know, I can add constant heat source using fvOptions. But, I have tabular data (time dependent heat source). Is there a way to use tabular data in fvOptions? Or something like fitting t the data to a curse and use an equation in fvOption? Best Regards Hafiz Last edited by mwaqas; June 27, 2019 at 07:09. |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
