Solver Fails to Locate Previous Timestep Solutions |
June 25, 2019, 15:59 |
Rep Power: 7 |
Hello. I am attempting to model a projectile at high speeds (approximately mach 2-3) and in a compressible, atmospheric environment. My solver of choice is sonicFoam. It is required for future studies that I be able to import .stl or .obj projectiles into the simulation, however for simplicity I currently model a cylinder with a semi-spherical nose. I use blockMesh to generate a background mesh of 3feet in the motion of the projectile (x1 direction) and 2feet by 2feet in the x2 & x3 directions. I then use the surfaceFeatureExtract and snappyHexMesh utilities to mesh around the projectile and attempt the solution via sonicFoam. For more simplicity, I have the simulation set up to run 1sec at 0.25sec time steps. Each time I recieve an error message which reads:
FOAM FATAL ERROR: cannot find file "/p/work/ryanc6/run/SabotDesign1/0.5/p" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 532. FOAM exiting Respectfully, ryanc6 |
June 26, 2019, 04:21 |
Yann
Rep Power: 29 |
Hello ryanc6
Have you run snappyHexMesh with the '-overwrite' option? If not, the default behavior of snappyHexMesh is to create new timeStep folders containing a polyMesh for the different meshings steps (castellated, snap, layers). This might explain why you get timestep folders with only polyMesh inside. Do you run you case in parallel? Yann |
June 26, 2019, 12:01 |
Rep Power: 7 |
Yann,
Thanks for the help! I am running snappyHexMesh with the overwrite option now. I did not expect a 1sec simulation with 5 timesteps to take this long; however, it has been running for just under an hour now. I will update when it finishes. This simulation is not the main study of my project, but rather the starting point. It runs in serial for now. With the required future complexity it will have to be run parallel at some point. I have been stuck on this part of the problem for a few days now, and my strategy for getting it solved is to reduce complexity as much as possible until a working solution is found. Then slowly increase complexity until the desired model and solution is achieved. ryanc6 |
June 26, 2019, 14:59 |
Attempted Parallel Run: Failed
Rep Power: 7 |
This system could not be completed within a reasonable time. Today I added a decomposeParDict file and tried again. I also fixed a few other bugs in the fvSchemes and fvSolutions pages. Now I receive this error after 15 minutes of processing:
--> FOAM FATAL IO ERROR: --> FOAM FATAL IO ERROR: Expected a '(' or a '{' while reading List, found on line 23: label 7Expected a '(' or a '{' while reading List, found on line 23: label 7--> FOAM FATAL IO ERROR: file: /p/work/ryanc6/run/SabotDesign1par/system/decomposeParDict at line file: Expected a '(' or a '{' while reading List, found on line 23: label 7/p/work/ryanc6/run/SabotDesign1par/system/decomposeParDict at line 23 file: /p/work/ryanc6/run/SabotDesign1par/system/decomposeParDict at line 23. From function char Foam::Istream::readBeginList(const char*) in file db/IOstreams/IOstreams/Istream.C. at line 134. FOAM exiting Code:
1 /*--------------------------------*- C++ -*----------------------------------*\ 2 | ========= | | 3 | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | 4 | \\ / O peration | Version: v1812 | 5 | \\ / A nd | Web: www.OpenFOAM.com | 6 | \\/ M anipulation | | 7 \*---------------------------------------------------------------------------*/ 8 FoamFile 9 { 10 version 2.0; 11 format ascii; 12 class dictionary; 13 object decomposeParDict; 14 } 15 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 16 17 numberOfSubdomains 44; 18 19 method simple; 20 21 coeffs 22 { 23 2 ((8 7 7)); //also tried (8 7 7) and (2 (8 7 7) ); 24 delta 0.001; 25 } 26 27 distributed no; 28 29 roots ( ); 30 31 32 // ************************************************************************* // ryanc6 |
June 27, 2019, 04:40 |
Yann
Rep Power: 29 |
Hello ryanc6,
I don't know what is the size of your mesh but the best way to do it would be to run blockMesh then decompose the case so you can mesh in parallel. It will be more time efficient than having to decompose the final mesh. About your decomposeParDict there are actually a syntax error and an error with the coefficients you have set. If your want to decompose your case on 44 cpus, it should be written for instance like this: Code:
coeffs { n (11 2 2); delta 0.001; } Have a look at the documentation : https://cfd.direct/openfoam/user-gui...ions-parallel/ About your problem with the refinementSurfaces in snappyHexMesh, there is probably an issue with the syntax, or a missing semicolon or bracket somewhere. (not necessarily at the line thrown in the error message, depending on what is missing. So you should also check if everything is fine before the refinementSurfaces section) Yann |
June 27, 2019, 20:39 |
Rep Power: 7 |
Thanks for the help Yann. I am out of that problem and onto the next sticky situation. Now I believe there is an error during the deconstruct portion. I get this error:
-->FOAM FATAL IO ERROR: Cannot find patchField entry for procBoundary4to12 file: /p/work/ryanc6/run/SDc/processor4/0/p.boundaryField From function [13] void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh][20] Here is my decompParDict file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 36; method simple; coeffs { n (4 3 3); delta 0.001; } distributed no; roots ( ); // ************************************************************************* // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 110000; boundaryField { sides { type zeroGradient; } inlet { type zeroGradient; } procBoundary4to0 { type processor; value uniform 110000; } procBoundary4to5 { type processor; value uniform 110000; } procBoundary4to8 { type processor; value uniform 110000; } procBoundary4to16 { type processor; value uniform 110000; } } // ************************************************** *********************** // Thanks for all the help! ryanc6 |
June 28, 2019, 08:50 |
Yann
Rep Power: 29 |
Hello ryanc6,
Your error is related to missing BCs in your variable files in the processor[0-N]/0 directories. the procBoundary* patches are created when you decompose your case and it corresponds to the interface patches between processors. It should be created in both processorN/constant/polyMesh/boundary and processorN/0/[U p ...] files, unless you don't have the 0 file already set up when you execute decomposePar. What are the steps leading to this error? what commands do you run? After decomposing, do you have the 0 repertory decomposed in every processor directory? Yann |
July 1, 2019, 13:23 |
Parallel Execution: Failed
Rep Power: 7 |
Yann,
Yes it seems the issue is in the decomposing of the files. Not all of my original BC's in the initial 0 folder are copied over into each processor#/0/* folders. An example of this is shown in the pressure folder. Here is my 0/p file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 100000; boundaryField { inlet { type fixedValue; value uniform 100000; } outlet { type waveTransmissive; field p; psi thermo:psi; gamma 1.3; fieldInf 100000; lInf 1; value uniform 100000; } projectile { type zeroGradient; } sides { type zeroGradient; } #includeEtc "caseDicts/setConstraintTypes" } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 100000; boundaryField { sides { type zeroGradient; } inlet { type fixedValue; value nonuniform 0(); } outlet { type waveTransmissive; gamma 1.3; fieldInf 100000; lInf 1; value uniform 100000; } procBoundary19to7 { type processor; value uniform 100000; } procBoundary19to15 { type processor; value uniform 100000; } procBoundary19to18 { type processor; value uniform 100000; } procBoundary19to23 { type processor; value uniform 100000; } procBoundary19to31 { type processor; value uniform 100000; } } // ************************************************************************* // Here is a copy of the error readout: Code:
--> FOAM FATAL IO ERROR: Cannot find patchField entry for projectile file: /p/work/ryanc6/run/SDn/processor19/0/p.boundaryField From function --> FOAM FATAL IO ERROR: void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] Cannot find patchField entry for projectile in file /app/unsupported/openfoam/1812/OpenFOAM-v1812/src/OpenFOAM/lnInclude/GeometricBoundaryField.C[17] at line 170file: ./p/work/ryanc6/run/SDn/processor17/0/p.boundaryField FOAM parallel run exiting To Answer your questions: Here is the part of my run script which executed the commands in order: Code:
aprun -n 1 blockMesh |tee blockmesh.out aprun -n 1 surfaceFeatureExtract |tee sfe.out aprun -n 1 decomposePar -force |tee decompose.out aprun -n 36 snappyHexMesh -overwrite -parallel |tee shm.out aprun -n 36 sonicFoam -parallel |tee sonicFoam.out aprun -n 1 reconstructParMesh -constant -fullMatch |tee rrm.out aprun -n 1 reconstructPar |tee reconstruct.out aprun -n 1 foamToVTK | tee foamToVTK.out Thanks for all the help. ryanc6 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Solver fails with compressible flow | Eric | CFX | 4 | February 4, 2006 09:28 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
