turbulence->k()
Old   June 20, 2019, 04:22
Default turbulence->k()
Vivek
vivek05 is on a distinguished road
I want to access "turbulent kinetic energy" and "nut" value in each cell. I am using OF-5.0 version. So I have implemented in following manner.
PHP Code:
volScalarField turb_nut turbulence->nut();
volScalarField turb_k turbulence->k();
forAll(mesh.cells(),celli) {
     if (
condition) {
Source[celli] = (...*(turb_k[celli]/(a+turb_nut[celli]))*...).value();
     else {
Source[celli] = scalar(0.0);
where Source is volScalarField
a is dimensionedScalar
... represents combination of constant and volScalarField
The way I am accessing "k" and "nut" is it correct??
What does -> operator do in turbulence->k()
Thanks,
Vivek S
vivek05 is offline   Reply With Quote
Old   June 21, 2019, 03:27
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by vivek05 View Post
PHP Code:
volScalarField turb_nut turbulence->nut();     volScalarField turb_k turbulence->k();     forAll(mesh.cells(),celli) {     if (condition) {     Source[celli] = (...*(turb_k[celli]/(a+turb_nut[celli]))*...).value();     }      else {     Source[celli] = scalar(0.0);      }     }
Thanks,
Vivek S
turbulence->k() is the RESIDUAL turbulent kinetic energy. the total tke would be the sum of the resolved tke and said residual tke.
Santiago is offline   Reply With Quote
Old   June 21, 2019, 04:03
Talking
Vivek
Thanks Santiago for your reply.
In LES simulation k() gives us subgrid kinetic energy. But I want to know how can I access ksgs in each cell? First I am storing turbulence-k() in variable called turb_k which is volumetric scalar field.
volScalarField turb_k = turbulence->k();
volSclarField turb_nut = turbulence->nut();
Then I am using forAll loop for spatial marching over cells
PHP Code:
forAll(sourceElsa celli) {
If(
condition)
sourceElsa = (...*turb_k[celli]/turb_nut[celli]*...);
Is it correct way to access turbulent kinetic energy?
It has also taking lot of time to calculate sourceElsa. How can I program it efficiently?
Thanks
Vivek S
Average Turbulence Intensity in LES M_Hego Visualization & Post-Processing 0 July 24, 2018 16:18
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Turbulence length scale Leonpolou FLUENT 2 January 23, 2013 08:26
How to implement turbulence in one Solver??? vahid.najafi OpenFOAM Programming & Development 0 July 29, 2012 06:46
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
