3-phase flow - compressibleMultiphaseInterFoam
Old   January 21, 2019, 18:18
Default 3-phase flow - compressibleMultiphaseInterFoam
eca
eca is on a distinguished road
Hello everybody,
I'm trying to solve 3-phase flow within a horizontal pipe with vertical pipe connection which has dead end. I want to start with the geometry consisting pure air, and then water and oil are coming from the inlet. How is the BCs and setFieldsDict supposed to be? I tried some different cases but every time I got different error messages such as maximum iteration number exceeded or floating point... Could you please share me your opinions and suggestions?
Thank you in advanced.
eca is offline   Reply With Quote
Old   February 8, 2019, 08:17
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
Hello Eca,
in case this is still up-to-date:
I had a similar question and just found this:
multiphaseInterFoam vs multiphaseEulerFoam
As for set fields you can set air as default (1 in defaultFieldValues). You do not need to set boxes for the inlet, it is defined in 0/alpha.*.
Stefanie.S.W. is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
CFX siphon two phase flow - boundary conditions bolus13 CFX 18 August 25, 2016 19:39
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
