January 16, 2019, 07:03 |
chtMultiRegionFoam and MRF
Kevin Habrock
Rep Power: 8 |
Dear Foamers,
I try to simulate a rotating System with different regions in chtMultiRegionFoam in combination with MRF. Actually I would like to use the OF 4.1 Version to solve this case but I have read that in this Version the solver doesn´t support multi reference frame. http://www.tfd.chalmers.se/~hani/kur...elayReport.pdf Do anybody of you know if the new OF 6.0 Version is able to combine chtMultiRegion and MRF? Best regards Last edited by Kevin.H; January 16, 2019 at 08:16. |
January 16, 2019, 09:25 |
Rep Power: 21 |
Yes it does.
You should see something like this in the UEqn.H file. If it is supported Code:
MRF.correctBoundaryVelocity(U); tmp<fvVectorMatrix> tUEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + MRF.DDt(rho, U) + turbulence.divDevRhoReff(U) == fvOptions(rho, U) ); |
January 16, 2019, 10:28 |
Kevin Habrock
Rep Power: 8 |
Bloerb, thank you for your quick answer.
As I see, this line is also implemented in OF 4.1. So it is possible that the Problem of my case is in front of the destop . The backround is that I try to combine two orthogonal hollow cylinder (solid) which were rotating in a fluid. The boundary conditions are fine right now, but when I try to implement the MRF with topoSet I get this result: Code:
--> FOAM FATAL ERROR: Cell 0 with cell centre (0.0337975 0.00132793 0.0004375) is multiple zones. This is not allowed. It is in zone magnet and in zone rotor From function void getZoneID(const Foam::polyMesh&, const cellZoneMesh&, Foam::labelList&, Foam::labelList&) in file splitMeshRegions.C at line 1217. FOAM exiting Maybe somebody has some experience with chtMultiRegion and MRF. |
January 16, 2019, 12:17 |
Rep Power: 21 |
Well you defined cellZones with topoSet which apparently overlap. This is not allowed.
Once you have your region meshes. Delete the polyMesh/cellZone file and define them with e.g topoSet -region regionA in a logical fashion |
January 17, 2019, 04:08 |
Kevin Habrock
Rep Power: 8 |
Thank you Bloerb for your support
I implemented the topoSetDict in the system/fluid Folder and the MRFProperties in the constant/fuid Folder and now it seems to work. It is really logic. Thank you! |
June 27, 2019, 14:55 |
shach
Rep Power: 7 |
Have you succeeded with chtMultiRegionFoam with MRF? I am working on a similar case and tried with this quite a while, however, didn't get it working...Is it possible for you to share a case from you? I really appreciate your help! Thanks! |
