PIMPLE solver error: residualControl must be given as single values |
August 20, 2018, 03:18 |
Martin
Rep Power: 8 |
I'm new to OpenFOAM but so far I've been able to correct all my mistakes, but this time I just cannot. I'm using PIMPLE to solve propeller case with my custom CAD propeller. I get this error as soon as I run mpirun:
[0] --> FOAM FATAL ERROR: [0] Solution convergence criteria specified in PIMPLE.residualControl must be given as single values. Corrector loop convergence criteria, if appropriate, are specified as dictionaries in PIMPLE.<loopName>ResidualControl. [0] [0] From function bool Foam::singleRegionConvergenceControl::readResidualControls() [0] in file cfdTools/general/solutionControl/convergenceControl/singleRegionConvergenceControl/singleRegionConvergenceControl.C at line 73. [0] FOAM parallel run exiting Code:
PIMPLE { correctPhi no; nOuterCorrectors 100; nCorrectors 3; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; residualControl { U { tolerance 1e-05; relTol 0; } p { tolerance 1e-04; relTol 0; } } } P.S. I created tet mesh with prismatic boundary layers. Mesh looks good to me, I also get "Mesh OK." after checkMesh but I have very big Max skewness of 3.11. It says OK but I've read OpenFOAM has problems with skewness above 0.9. How can I have 3.11?? Mesh non-orthogonality Max is 70.3 and average 14.9 Since I started using OpenFOAM I've been having problems whenever I had tetrahedral mesh. This time with propeller case I followed youtube tutorial but still no luck. Is there any OF solver that works with tet meshes? |
August 20, 2018, 08:53 |
Martin
Rep Power: 8 |
I fixed this problem by setting residualControl like this:
residualControl { U 1e-05; p 1e-04; } This happens to me whenever I try to solve case with tetrahedral mesh. What am I doing wrong? |
August 31, 2018, 05:58 |
Rep Power: 11 |
Hi artymk4.
First thanks for the info with the residualControl. I had the same problem. But now to your problem. What did you write in your fvSolution file for nOuterCorrectors under the pimple Algorithmus? |
September 5, 2019, 13:19 |
Khaled Yassin
Rep Power: 7 |
Hi all, I had the same problem. The problem was with OF version that I am using. OF5 uses the form:
residualControl { U { tolerance 1e-05; relTol 0; } p { tolerance 1e-04; relTol 0; } } Code:
-- Best Regards, Khaled Yassin, Research Assistant Institute for Energy and Environmental Research (IEK-14) Forschungszentrum Jülich |
September 5, 2019, 15:09 |
#5 | |
CFD USER
Rep Power: 7 |
I cannot find any tutorial in OF5 that uses that format. OF5 uses the following: Code:
residualControl { U 1e-05; p 1e-04; } If want to verify this, run the following grep or another tool that support pcre regex, e.g: pcregrep: Code:
pcregrep --color -r -M '^\h*residualControl\s*{[^}]*}' $FOAM_TUTORIALS |
February 9, 2021, 00:39 |
Tushar Survase
Rep Power: 6 |
For OF-V5 and OF-V6, residual control needs to be given as single value. OF-v1906 and OF-v2006 asks for dictionary residual control. While OF-V5 and OF-V6 requires single value.
residualControl { p 0.001; p_rgh 0.001; U 0.001; k 0.001; epsilon 0.001; omega 0.001; nuTilda 0.001; } Its just an example on how to implement residual control in OF-v5 and OF-v6. |
May 15, 2021, 19:28 |
Jairo A. Gutiérrez S
Rep Power: 12 |
Yeah, I ran into the same issue when using an OpenFOAM.com case in OF-V8. Fixed.
August 25, 2024, 03:07 |
Lubelskie
Rep Power: 3 |
Which file should I edit in that way? I have same error with HelyxOS and OpenFoam but I`m not sure where should I put your solution.
Why does this happen? |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 12:54 |
Poisson equation in custom solver diverges for large boundary values | babakflame | OpenFOAM Running, Solving & CFD | 2 | May 23, 2017 21:11 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 23:38 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
