August 8, 2022, 10:49 |
#21 |
Michael Alletto
Rep Power: 16 |
Rhoinf is the fluid density. The density of the solid is not defined explicitly since in the 6dof solver you define the mass of the solid. Visualisation with paraview can be done by writing out at different times steps
August 9, 2022, 10:25 |
#22 |
Goind Sharma
Rep Power: 8 |
Thanks,
I mean by visualization to see the motion of the sphere object. As it run in paraview, solid object from the boundary folder remains stationary. One more thing: How can I reduce the diffusion if possible by any means? As I understand by grid refinement upto some extend it can be done. Govind |
August 9, 2022, 16:08 |
#23 |
Michael Alletto
Rep Power: 16 |
For moving meshes the mesh is written at every time step the other fields are written out. So the sphere boundary should also be written. Diffusion can be reduced be higher order schemes or finer mesges
August 13, 2022, 07:30 |
#24 |
Goind Sharma
Rep Power: 8 |
HI,
I have modified the settling sphere case with using of sphere stl file to generate the mesh. It runs for few second only. I have attached the case file with including "log" containing the output of the terminal. I have tried with higher as well lower time step. I do not getting the key point. Can one please look at this case and suggest me something to figure out the issue? Govind |
Validation in Transient tasks | MaxakCh | FLUENT | 0 | May 17, 2013 09:59 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 11:22 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
Validation test for 2d euler equations in subsonic regime with canonical squares | panou | Main CFD Forum | 2 | August 24, 2011 16:21 |
Urgent: RAE 2822 validation | NID | Main CFD Forum | 0 | September 3, 2004 11:34 |
