How to specify pMax and pMin in OF 5.0 ?
Old   February 5, 2018, 11:26
Default How to specify pMax and pMin in OF 5.0 ?
Deep
deepbandivadekar is on a distinguished road
I'm getting warnings during my run of rhoPorousSimpleFoam like these
--> FOAM Warning :
    From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool)
    in file cfdTools/general/pressureControl/pressureControl.C at line 125
    Reading "/OpenFOAM/x/system/fvSolution.SIMPLE" from line 52 to line 66
    'rhoMax' specified rather than 'pMax' or 'pMaxFactor'
    This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable.
--> FOAM Warning :
    in file cfdTools/general/pressureControl/pressureControl.C at line 182
    'rhoMin' specified rather than 'pMin' or 'pMinFactor'
    This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable.
So when I thought of defining pMax and pMin instead and replaced rhoMax and rhoMin in fvSolutions, I got an error.
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 55 the word 'pMax'
file: /OpenFOAM/x/system/fvSolution.SIMPLE.pMax at line 55.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
Following is from the pressurecontrol.c file
if (dict.found("pMax") && dict.found("pMin"))
        pMax_.value() = readScalar(dict.lookup("pMax"));
        limitMaxP_ = true;
        pMin_.value() = readScalar(dict.lookup("pMin"));
        limitMinP_ = true;
Does that mean, I need to create two separate dictionary files named pMax and pMin ? And do these go in the system folder or it doesn't matter?
I didn't find a single thread involving pMin or pMax or pMinFactor and pMaxfactor, that was surprising.
deepbandivadekar is offline   Reply With Quote
Old   August 1, 2019, 07:37
Default any solution?
Owais Shabbir
Owais Shabbir is on a distinguished road
Did you find any solution to that I am having the same problem.
I am trying running chtMultiRegionSimpleFoam tutorial on OFv6 but after some minor modification, I am recieving this error as you have described before.
Could you share your solution if you remember it?
Thanks
Owais
Owais Shabbir is offline   Reply With Quote
