Integration steps greater than maximum!!!
Like Tree2Likes
  • 2 Post By omid20110
Old   December 15, 2017, 01:45
Default Integration steps greater than maximum!!!
Sadegh Ebadi
omid20110 is on a distinguished road
Hello everybody
I am simulating a heptane combustion via sprayFoam (OF 5.x)
Can anyone tell me what's this error for?
--> FOAM FATAL ERROR:
Integration steps greater than maximum 10000xStart = 0, xEnd = 5.53853e-08, x = 4.02297e-08, dxDid = 2.29093e-12
From function virtual void Foam::ODESolver::solve(Foam::scalar, Foam::scalar, Foam::scalarField&, Foam::scalar&) constin file ODESolvers/ODESolver/ODESolver.C at line 191.
FOAM exiting
I get this error at time=0.0008 s
then I stopped the simulation and just rerun the simulation, it continued till time=0.00108 then again I get the same error!
omid20110 is offline   Reply With Quote
Old   December 17, 2017, 11:20
Sadegh Ebadi
No body knows about this error?!
Old   January 1, 2018, 17:07
Retired Super Moderator
Bruno Santos
Quick answers:
  1. Not enough information, please follow the instructions given here:
    https://www.cfd-online.com/Forums/openfoam/98988-how-give-enough-info-get-help.html
  2. I'm not familiar with "Integration steps greater than maximum 10000", but usually this is related to something going outside of the known expression ranges. For example, if something has a pressure and temperature that is outside of the thermodynamical polynomials, e.g. any temperature below 200K or above 5000K.
Old   January 2, 2018, 04:08
Sadegh Ebadi
Originally Posted by wyldckat View Post
Quick answers:
It's because of the ODE model. I have changed the ODE model...
Old   January 2, 2018, 07:40
Bruno Santos
So does that mean that by changing the ODE model this was fixed or that this happened because you changed ODE model?
And between which models did you change?
Old   January 3, 2018, 07:15
Sadegh Ebadi
Yes by changing ODE model in the chemistryProperties file this problem was fixed.
I changed it from seulex to Rosenbrock34.
wyldckat and pattim like this.
Old   October 2, 2020, 18:39
Patti Michelle Sheaffer
pattim is on a distinguished road
Thanks for the suggestion - I'll give that a try. Could also try rhodas...
pattim is offline   Reply With Quote
Old   October 30, 2022, 09:56
mactone hsieh
mactone is on a distinguished road
Hello everybody
FOAM exiting
I encountered the same issue.
However, I start with seulex_LAPACK.
Then I tried all the ODESolvers including
Euler, EulerSI, RKCK45, RKDP45, RKF45, Rosenbrock12, 23, 34, SIBS, Trapezoid, rodas23, rodas34, selux.
All failed.
I am running the SandiaD_LTS case from the tutorial but changing the reaction mechanism to JL4 and using ode_pyJac as the ode solver.
Still can't figure out why! Maybe it's due to the ode_pyJac from DLBFoam.
Any suggestions?
mactone is offline   Reply With Quote
Old   November 16, 2022, 09:07
NuclearLeaf's Avatar
Mario Zuber
NuclearLeaf is on a distinguished road
Can also add
solver Euler;
absTol 1e-8;
relTol 0.1;
Not sure if that info still helps
NuclearLeaf is offline   Reply With Quote
Maximum Temperature greater than the boundary temperature sathwik718 STAR-CCM+ 3 May 19, 2014 18:05
creating a chart for a value vs time steps mhabibnia CFX 1 July 3, 2013 03:45
Maximum Lift Prediction gfoam Main CFD Forum 3 August 22, 2012 08:29
Temperature greater than maximum range byanw81 STAR-CD 1 July 24, 2009 11:45
how to deal with "particle Exceeded integration" steven CFX 1 August 30, 2005 08:03
