Strange behaviour using compressibleInterFoam
Old   November 20, 2017, 16:57
Default Strange behaviour using compressibleInterFoam
bbita is on a distinguished road
Dear Foamers,
I am using compressibleInterFoam. I need to modify the solver but before that I needed to do some simple tests for validation. I modified depthCharge2D case. I assumed alpha.water is 1 everywhere and I have constant temperature and pressure. I set gravity equal to zero. I expected to see zero iteration for all parameters in addition to zero initial and final residuals.
Surprisingly, the iterations exceed 1000 for pressure and temperature although when I look at the files, the pressure and temperature were equal to initial values. I am wondering if there is an error in residual calculations (initial residual is not zero for pressure and temperature!).
Any suggestions?
bbita is offline   Reply With Quote
compressibleinterfoam, heat balance, residual, temperature
Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle TobM OpenFOAM Running, Solving & CFD 2 May 11, 2016 07:34
[sprayFoam] strange spray formation behaviour pbalz OpenFOAM Running, Solving & CFD 0 March 23, 2015 12:41
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 15:00
Strange residuals behaviour xxxx Main CFD Forum 1 July 13, 2013 15:40
Strange behaviour when using LienCubicKE and NonlinearKEShih hani OpenFOAM Running, Solving & CFD 20 March 6, 2013 11:06
