rhoSimplefoam with error " Maximum number of iterations exceeded " |
June 15, 2017, 03:49 |
Raye XIe
Rep Power: 9 |
Hi All,
I was running NACA0012 airfoil (AoA=15 deg) with rhoSimpleFoam with Re=6million. I ran checkMesh and the mesh was okay. The following error happened when the residuals seem to be fine (~ 1e-5) (also see my log file attached). 1) Is there any way (or Should I try) to increase the maximum # iterations allowed? 2) What might cause this error? Code:
--> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted (core dumped) Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nCellsInCoarsestLevel 20; } "(U|e|nuTilda)" { solver smoothSolver; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; nCellsInCoarsestLevel 20; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin 0.1; rhoMax 1.0; transonic yes; consistent yes; residualControl { p 1e-5; U 1e-5; e 1e-5; nuTilda 1e-5; } } relaxationFactors { fields { p 0.15; rho 0.05; } equations { p 0.3; U 0.3; e 0.3; nuTilda 0.3; } } Thanks, Raye Last edited by raye_xie; June 15, 2017 at 17:36. Reason: add attachment |
June 19, 2017, 08:23 |
Alex
Rep Power: 12 |
There is a way to increase the iterations for the thermo model by modifying the src and recompiling it. However, from my experience, this is not necessary and you should not do that.
It's like when a guy tells you that your car has a flat tire. But instead of fixing it you blindfold the guy or tell him to be more tolerant towards flat tires in general. This might not be the fix, but I am curious: You calculate at ambient pressure and compressible. Your rho limiter keeps the density below 1 while the density of air at 300k and 1atm is already 1.184 kg/m3 (source wolframalpha). What I mean is that you don't let the solver calculate the actual rho values but instead give him an unrealistic limiter (from my point of view). This can lead to miscalculation of the internal energy. Try increasing the max to 1.3 and see how it turns out. Also, after the first 100 iterations, you can start increasing your URF for anything except p to around 0.7. Cheers Alex |
June 20, 2017, 00:55 |
#3 | |
Raye XIe
Rep Power: 9 |
Hi Alex,
Thank you for the advice. The Rhomax was actually the origin of my problem. I copied the fvSolution file from another tutorial and never noticed that there is a density limiting setting. One follow up question. Why do you suggest I turn down the URF after 100 iteration, not from the beginning? Best, Raye Quote:
June 20, 2017, 02:30 |
Alex
Rep Power: 12 |
Well, my point with the URF was not that you should keep them low for 100 iterations but that you should set them higher at some point in your simulation.
With the rho-based solvers, there can be certain instabilities while initializing the flow field. That's why low URF make sense in the beginning. Later, you should be able to set them to around 0.7 and 1 for rho. As always, this also depends on the mesh and the schemes of course. Cheers Alex |
June 20, 2017, 02:34 |
Raye XIe
Rep Power: 9 |
I see, Thank you!
June 20, 2017, 03:22 |
Alex
Rep Power: 12 |
One more thing. You have the transonic option turned on in the SIMPLE settings.
If your theoretical Mach No is below 0.8, you can put the option to "no", which further increases stability. |
June 20, 2017, 03:35 |
Raye XIe
Rep Power: 9 |
Yeah, I also noticed that. It's pretty weird that when I had the wrong Rho setting, turning on transonic cancelled out the error and helped me get better pressure result (even my rho is wrong). Now I changed the rhomax and turned off the transonic option, I am able to get good results and the solver converges way better. But I'm still wondering what exactly does the transonic option do. Thanks!
June 20, 2017, 03:48 |
Alex
Rep Power: 12 |
Have you ever seen an experiment and theory of a CD (coverging diverging) nozzle? It shows that the physics of flows become highly unlinear when dealing with high Mach numbers. The solver doesn't know that beforehand so you have to give it a hint about what set of equations to set up for solving. So if you know the flow is not gonna reach Ma > 0.9 at some point you are better off turning the option to "no".
September 26, 2019, 13:17 |
#9 |
Arthur
Rep Power: 12 |
In my case it was boundary conditions.
I solved the problem (no transitory) starting with lower values on BCs and increasing it sofetly once the previous solution converged! |
May 29, 2024, 00:02 |
Maximum number of iterations openfoam
#10 | |
Ankit
Geometry: 1. Room: With floor, roof and side walls. 2. Server(Rack): I created a simple cube that will generate heat (to make it simple). When i run "rhoSimpleFoam", i am getting below error. Please help. -> FOAM FATAL ERROR: (openfoam-2206 patch=221104) Maximum number of iterations exceeded: 100 when starting from T0:348.8794608 old T:467.2625449 new T:490.4542647 f:-45038.05359 p:101325 tol:0.03488794608 From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::Boussinesq<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::Bou ssinesq<Foam::specie> >, Foam::sensibleInternalEnergy>] in file ./src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::simpleExit(int, bool) at ??:? #2 ? at ??:? #3 ? at ??:? #4 ? at ??:? #5 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam #6 ? in /lib/x86_64-linux-gnu/libc.so.6 #7 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #8 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam Aborted (core dumped) Below are the BC and log file "U" dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { "(roof|floor|side_walls|rack)" { type fixedValue; value uniform (0 0 0); } "(intake_1|intake_2|intake_3|intake_4)" { type surfaceNormalFixedValue; refValue uniform -1; } "(outlet_1|outlet_2|outlet_3|outlet_4|outlet_5 |out let_6|outlet_7|outlet_8|outlet_9)" { type zeroGradient; } } "T" dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { "(roof|floor|side_walls)" { type zeroGradient; } rack { type externalWallHeatFluxTemperature; mode flux; q uniform 681; // W/m^2 value uniform 300; kappaMethod fluidThermo; kappa none; Qr none; } "(intake_1|intake_2|intake_3|intake_4)" { type fixedValue; value uniform 283; } "(outlet_1|outlet_2|outlet_3|outlet_4|outlet_5 |out let_6|outlet_7|outlet_8|outlet_9)" { type inletOutlet; value $internalField; inletValue $internalField; } } // ************************************************** *********************** // "U" dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { "(roof|floor|side_walls|rack)" { type fixedValue; value uniform (0 0 0); } "(intake_1|intake_2|intake_3|intake_4)" { type surfaceNormalFixedValue; refValue uniform -1; } "(outlet_1|outlet_2|outlet_3|outlet_4|outlet_5 |out let_6|outlet_7|outlet_8|outlet_9)" { type zeroGradient; } } // ************************************************** *********************** // "Log.file" /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _8993af73-20221106 OPENFOAM=2206 patch=221104 version=2206 Arch : "LSB;label=32;scalar=64" Exec : /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam Date : May 29 2024 Time : 10:26:46 Host : I7MS7D40 PID : 512545 I/O : uncollated Case : /home/ubuntu/Desktop/Ankit_Projects/Ageing_room_simulation_with_rack/steady nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 2 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.001 field k tolerance 0.001 field omega tolerance 0.001 field e tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState Boussinesq; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi pressureControl pMax 202650 pMin 10132.5 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.5555555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; decayControl false; kInf 0; omegaInf 0; } No MRF models present Creating finite volume options from "constant/fvOptions" Selecting finite volume options type limitTemperature Source: limitT - selecting all cells - selected 880234 cell(s) with volume 903.022348 Starting time loop Time = 3 DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.0008832352532, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.0008911528477, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.0009263606855, No Iterations 1 DILUPBiCGStab: Solving for e, Initial residual = 0.99999996, Final residual = 0.0004638375708, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells, with min limit 101 limitTemperature limitT Upper limited 0 (0%) of cells, with max limit 600 limitTemperature limitT Unlimited Tmin 293 limitTemperature limitT Unlimited Tmax 293 --> FOAM FATAL ERROR: (openfoam-2206 patch=221104) Maximum number of iterations exceeded: 100 when starting from T0:348.8794608 old T:466.3603085 new T:485.7612558 f:-48051.46157 p:101325 tol:0.03488794608 From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::Boussinesq<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::Bou ssinesq<Foam::specie> >, Foam::sensibleInternalEnergy>] in file ./src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::simpleExit(int, bool) at ??:? #2 ? at ??:? #3 ? at ??:? #4 ? at ??:? #5 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam #6 ? in /lib/x86_64-linux-gnu/libc.so.6 #7 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #8 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam |
June 17, 2024, 13:00 |
#11 | |
Rep Power: 6 |
I have the same problem. Have you been able to solve this? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
