sclsVOFFoam
Old   June 2, 2017, 14:37
Default sclsVOFFoam
Masoumeh Gharaati
mgharaati is on a distinguished road
Dear all
I 'm using sclsVOFFoam solver. http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf
I 'm modeling droplet impact into liquid layer. the liquid is water and the gas is air. When I 'm using the
transportProperties
it works but when I change viscosity to air and gas I face to these errors.
p { margin-bottom: 0.1in; line-height: 120%; } #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 Foam::fvMatrix<double>::solve() at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
Would you please help me for solving this?
mgharaati is offline   Reply With Quote
Old   June 20, 2017, 23:59
Nguyen Duy Trong
ndtrong is on a distinguished road
"Foam::symGaussSeidelSmoother::smooth(Foam::wo rd const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? "
I think there is problem of variable name, you should keep same variable name. On the other hand, you simply change value of the variable you want to change
ndtrong is offline   Reply With Quote
Old   June 22, 2017, 12:51
Masoumeh Gharaati
I just changed the value of variables. I didn't change any name.
Old   June 22, 2017, 13:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Hi all,
@mgharaati
Your solution diverges. Why your solution diverges? It is difficult to say from what you have posted.
This
is rather enigmatic.
alexeym is offline   Reply With Quote
Old   June 26, 2017, 16:49
Masoumeh Gharaati
It 's related to Courant number. I check the log file and Courant number got too much. Then, I tried to keep Courant number under 0.1 but it didn't work too.
Old   June 28, 2017, 04:05
Nguyen Duy Trong
I don't think it work by changing of variable's value. I mean you change the name of variable, you should look into the createFields file to see how your code read variable name.
Old   June 28, 2017, 04:07
Nguyen Duy Trong
please upload your transportProperties file in constant folder
Old   July 5, 2017, 15:17
Masoumeh Gharaati
Please find the attached file.
p.zip
Old   July 6, 2017, 06:25
Nguyen Duy Trong
Attachment 57111
I am so sorry. I am wrong with my opinion.
Maybe there are another reason for your errors.
Sorry about that
Old   September 30, 2018, 02:17
krishna kant
kk415 is on a distinguished road
Hi All
I am also solving sclsVOFFoamsf and getting a similar error like shown in the original post. It is coming from the reinitialization step. Can anyone guide what could possibly went wrong?
solve the reinitialization equation
#2 ? at sigaction.c:?
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 ? at ??:?
#6 __libc_start_main at ??:?
#7 ? at ??:?
I have individually look on the output of all individual values involved like psi, grad(psi) deltaTau they all look fine. The boundary condition is cyclic for all variables.
kk415 is offline   Reply With Quote
Old   September 30, 2018, 03:32
Masoumeh Gharaati
Hi
I am afraid to say that I couldn't solve the problem and I still get the same error.
Originally Posted by kk415 View Post
Hi All
#5 ? at ??:?
#7 ? at ??:?
Old   October 31, 2018, 22:53
Huang Xianbei
huangxianbei is on a distinguished road
Hi All
#5 ? at ??:?
#7 ? at ??:?
Hi, I got the same error. I tried several turbulence models and still got the error. I think it should be attributed to the solver rather than the turbulence models.
The problem remains in the solveLSFunction.H:
psi = psi + psi0/mag(psi0)...
psi can be zero so that the divide operator will lead to divergence.
Change:
psi = psi + psi0/max(mag(psi0),VSMALL)
This can avoid the error. However, I still can not get a converged solution for my case. The calculation crashed after a few iterations
huangxianbei is offline   Reply With Quote
clsvof, viscosity
