flow around a cylinder with different step using icoFoam |
August 24, 2016, 03:38 |
Aaron
Rep Power: 10 |
Hi, foamers
I run a flow around a circular cylinder using icoFoam, and I get everything OK,lift and drag coefficient, St number are in agreement with literature, but the lift coefficient different with different time step. can you give me some suggestions? |
September 1, 2016, 08:24 |
Artur
Rep Power: 20 |
HI,
It seems the difference is only in phase shift between the two signals, correct? If so then I wouldn't worry about it too much as the period up to when the flow becomes fully developed is not very physical anyway (you probably star the simulation with U=Uinf everywhere, including right next to the cylinder?). All the best, A |
September 2, 2016, 05:45 |
Aaron
Rep Power: 10 |
Hi,Artur
Thanks for your reply, my consideration is that flow over a cylinder should be time-independent, if I reduce time-step, the simulation phenomena should be the same, why I using icoFoam and PISO algorithm, the lift coefficient phase change? Is the PISO algorithm problem?or I get something wrong? Best wishes, Aaron |
September 2, 2016, 05:52 |
Artur
Rep Power: 20 |
What I'm trying to say is that your initial condition may not be physically correct and if that's the case the initial transients are not going to be either. If you'd like to simulate development of the instabilities you should initialise your simulation with zero velocity and then ramp it up to the speed you want (analogous to putting the geometry into a wind tunnel and turning it on). Then you should get similar results with both time steps. For problems like this one it's customary to just discard the initial period and only consider the data once the flow is fully developed, however.
All the best, A |
September 2, 2016, 06:06 |
Aaron
Rep Power: 10 |
hi, Artur
many thanks for your detailed explanation, I will try it best wishes, Aaron |
November 16, 2023, 22:58 |
loriro
Hey Aaron, do you have the case setup for the cylinder? I am encountering some issues. Also did you manage to solve your problem?
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 05:50 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
