Error: Cannot find file....line 0
Old   May 3, 2016, 07:24
Default Error: Cannot find file....line 0
Patrick
linox is on a distinguished road
Hi there,
I am new to openFoam and will really need your help.
I am trying to run a simulation of flow in an open channel. I considered a very simple box-like structure to represent my channel.
I used the enGrid software to create the mesh and boundary conditions, including setting up the solver parameters.
Upon running the set-up in openFoam, i got the following error:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/hp/OpenFOAM/hp-3.0.1/run/myTrials/box/constant/turbulenceProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
My interpretation of the error is that the turbulenceProperties file is missing in the Constant folder.
But the exported set-up from enGrid contain the following files in the Constant folder: RASProperties and transportProperties, along with the polymesh folder. And uses the simpleFoam solver.
The 0 - case folder contains the following files: epsilon, k, omega, p and U
I will greatly appreciate your help in dealing with this problem.
Regards
Linox
linox is offline   Reply With Quote
Old   May 4, 2016, 05:10
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hi linox,
I have never used enGrid but it seems like you are right and the turbulenceProperties file is missing in your constant folder.
Guessing from the files in your 0 folder you are using a k-epsilon-model?
Then your turbulenceProperties file should look something like this:
*--------------------------------*- C++ -*----------------------------------*\
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType  RAS;
RAS
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
Also you said, that you are simulating an open channel? Are you also simulating the free surface? Then you have some more stuff missing. For example the alpha.water file in the 0 directory. I would maybe take a look at some tutorial, maybe this:
/OpenFOAM/OpenFOAM-X.X.X/tutorials/multiphase/interFoam/ras/waterChannel>
Hope this might help you!
Mona
mo_na is offline   Reply With Quote
Old   May 4, 2016, 12:20
Patrick
Hi Mona,
Thanks for the suggestion. You are right, I do have a lot of input files missing. I am now including the missing files with the help of the tutorials.
Will certainly consult your advice again if i get stocked
cheers!
linox
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
