Reconstructing cyclicAMI fails
Old   April 27, 2016, 09:44
Default Reconstructing cyclicAMI fails
Perfectdark is on a distinguished road
Hey,
I'm having problems reconstructing my case with periodic bc (cyclicAMI). The mesh was imported with fluent3dmeshtofoam. It's got some areas where the periodic faces don't match very well, so I needed to run the case with cyclicAMI Interface and 'lowWeightCorrection 0.2'. No problems running the case in non-parallel, but decomposing it fails at the reconstruction of the processors. This is probably because of the bad cells, where the weight is too low:
AMI: Patch source sum(weights) min/max/average = 0, 1.00154, 0.997058
AMI: Patch source identified 8 faces with weights less than 0.2
AMI: Patch target sum(weights) min/max/average = 0, 1.00066, 0.996335
AMI: Patch target identified 15 faces with weights less than 0.2
The case runs fine, even in parallel, just the reconstruction fails
preserving the patches doesn't do the trick, unfortunately.
Any suggestions for this kiind of problem?
I'M using OF2.3.1
Perfectdark is offline   Reply With Quote
Old   April 29, 2016, 04:49
Antimony is on a distinguished road
Does reconstructParMesh work fine?
Regards,
Antimony
Antimony is offline   Reply With Quote
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 07:05
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 08:21
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 12:25
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 23:36
