January 12, 2016, 13:06 |
Boundary/patch in middle of domain
Ali
Rep Power: 13 |
Hello
I'm wanting to assign a boundary condition in the middle of my domain E.g an outlet/inlet. Does anyone know how to do this? I created a geometry in Fluent with two regions, and there was the interface region (between the blue and yellow), which I could assign conditions. This wouldn't run through the whole domain, as there was two regions (obviously). When I stitched the regions together, the solver works, but the boundary disappeared, and thus I'm back to square one. I know this is to be expected, as there is no boundary there, but I hope someone can understand my problem... Any help is appreciated |
January 13, 2016, 15:22 |
have a look at creatBaffles utility on how to do this.
Ripudaman Manchanda
Rep Power: 13 |
Essentially you need to find the faces that you want to make a boundary from and make faceSet using setSet or topoSet.
Then you will have to convert that faceSet to a faceZone by using setsToZones utility. Then run creatBaffles to create a baffle boundary from the new faceZone. Before you run createBaffles make sure that the name of the patch you are trying to create has been included in both your boundary file as well as the field variable files in time 0 directory. You can also use mergeOrSplitBaffles to split the single boundary plane into two coplanar boundary planes belonging to the same patch. Good luck Ripu |
January 15, 2016, 06:50 |
Ali
Rep Power: 13 |
Thanks Ripu
I'll give that a try. |
January 18, 2016, 13:20 |
Ali
Rep Power: 13 |
I've managed to insert a baffle into the domain, and can set BC's on it. Does anyone know how to set the baffle to 'invisible', so as only to read fields from it? Or a boundary condition which allows the fluid to pass through?
Cheers |
January 20, 2016, 13:22 |
Ali
Rep Power: 13 |
Here is an image of what I'm talking about.
This depicts an inlet at the top, and outlet at the bend, another inlet in the same place, and another outlet on the right. What I'm wanting to do is make the boundary invisible to the majority of the solver (it's multiphase), but keep it as an outlet for other parameters. I've been stuck for a while now with this! regards |
November 27, 2020, 02:46 |
Xiangjie Wang
Rep Power: 7 |
Hi Ali,
Did you solve this problem? I am also encountering such a problem. Hope you can see it after several years you posted it! Regards, Xiangjie |
November 27, 2020, 04:19 |
Ali
Rep Power: 13 |
Hi.
Yes I think I did. See my PhD thesis for more info. http://digitool.lib.strath.ac.uk/R/?...bject_id=31589 |
December 3, 2020, 00:42 |
Xiangjie Wang
Rep Power: 7 |
Hi Ali,
Thanks for your reply and sorry for my late replying! I will look into the thesis! Bests, Xiangjie |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
periodic condition and Rotary inner domain | aja1345 | FLUENT | 0 | August 5, 2015 02:51 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 04:14 |
Error (2 isolated fluid regions) with an englobing domain | syens | CFX | 2 | January 12, 2012 11:55 |
How to add turbulence purtubation in the middle of the computational domain? | ivanbuz | FLUENT | 1 | August 27, 2009 02:14 |
