How to get area, face normal vector of a patch
Like Tree5Likes
  • 5 Post By GCMS_A
Old   May 27, 2015, 11:27
Default How to get area, face normal vector of a patch
GCMS_A is on a distinguished road
Hi everyone,
I have this code that I would like to modify to fit to my problem :
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void velocityChannelWallFunctionFvPatchField::updateCoeffs()
    if (this->updated())
        return;
//  Set up access to the mesh
    const fvMesh& mesh = patch().boundaryMesh().mesh();
//  Set up access to the internal velocity field.
    const volVectorField& UCell = db().objectRegistry::lookupObject<volVectorField>("U");
//  Interpolate velocity on the cell faces.
    surfaceVectorField UFace = fvc::interpolate(UCell);
//  Get face areas (individual and global sum) (note that "gSum" is used as
//  opposed to "sum" because "gSum" is parallel-aware --- it gathers sums from
//  each processor to which this patch belongs and makes the global sum)
    const scalarField area = patch().magSf();
    scalar areaTotal = gSum(area);
//  Get perpendicular distance from cell center to boundary.  In other words,
//  the height of the y_1/2 grid level.
    const scalarField y12 = 1.0/patch().deltaCoeffs();
//  Get face normal vectors
    vectorField normal = patch().nf();
I have modified it like this :
        return;
    label patchIndexUp = mesh.boundaryMesh().findPatchID("topWall");
    Info << "patchIndexUp =" << patchIndexUp << endl;
    label patchIndexDown = mesh.boundaryMesh().findPatchID("bottomWall");
    Info << "patchIndexDown =" << patchIndexDown << endl;
but I don't know how can I get the area, face normal vectors ... of the patchIndexUp & the patchIndexDown.
If anybody know how to do this, I would be very happy to have explanations.
Thank you
Anass
GCMS_A is offline   Reply With Quote
Old   May 28, 2015, 04:52
Default following ...
Hi everyone,
I finaly found how to get the face area for the two patches (patchIndexUp & Down).
My code became as follow :
        return;
//  const scalarField area = patch().magSf();
//  scalar areaTotal = gSum(area);
    const surfaceScalarField& magSf = mesh.magSf();
    scalar areaUpTotal = gSum(magSf.boundaryField()[patchIndexUp]);
    scalar areaDownTotal = gSum(magSf.boundaryField()[patchIndexDown]);
    //const scalarField y12 = 1.0/patch().deltaCoeffs();
    const scalarField yUp = mesh.boundary()[patchIndexUp].deltaCoeffs();
    const scalarField yDown = mesh.boundary()[patchIndexDown].deltaCoeffs();
    //vectorField normal = patch().nf();
    vectorField normalUp = mesh.Sf().boundaryField()[patchIndexUp];
    vectorField normalDown = mesh.Sf().boundaryField()[patchIndexDown];
My question now is : For this part of code :
Is someone could explain to me the meaning of these lines of code ? and how can I change them if I want to find the values ​​of Ucell and UFace for the patchIndexUp and patchIndexDown ?
Thank you
Anass
Old   September 16, 2018, 12:20
Pavan
pvpnrao is on a distinguished road
GCMS_A
Thank you very much for posting the fix for calculating the areas of other boundaries within a boundary condition.
You saved me a lot of time today. I understand your query in in the second post is three years old. I am sure you must have figured it.
Let me know if you still need this information.
pvpnrao is offline   Reply With Quote
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
