December 14, 2014, 23:17 |
sprayFoam: thetaOuter and thetaInner
Neilson Whit
Rep Power: 15 |
Dear All
I simulate a full cone spray with an angle of 30 -degree. In the constant/sprayCloudProperties file, I enter two parameters as follows; Code:
thetaInner constant 0.0; thetaOuter constant 15.0 ; What is the thetaOut ? half-cone angle? or full-cone angle? |
December 15, 2014, 16:16 |
Rep Power: 16 |
as you found out by checking the source code, the outer angle is the half angle of the full cone (at least for OpenFOAM version 2.1 or later) Kind regards Chrisi |
December 19, 2014, 08:24 |
saeed
Rep Power: 13 |
I think the angles (inner and outer) are half-cone and are measured from center-line. then, for full-cone sprays always theta inner = 0 and theta outer is half-cone of spray angle.
July 1, 2016, 15:29 |
Luis Fernando Rua Mojica
Rep Power: 10 |
Hi saeedshayae,
can you tell me the reference of that image? I'm learning about the injection process and that image is good, I want know to more about it thanks |
July 1, 2016, 17:23 |
#5 | |
saeed
Rep Power: 13 |
"Modelling of Gasoline and Ethanol Hollow-Cone Sprays Using OpenFOAM, Chen Huang and Andrei Lipatnikov,JSAE 20119069 SAE 2011-01-1896" . |
July 4, 2016, 18:31 |
Rep Power: 10 |
thanks!!!!
July 17, 2019, 03:45 |
Cone Spray Angle
Pranav Uchiha
Dear All,
Can I ask how did you calculate the cone angle which you needed, theoretically ? or it was an experimental result ? Probably this is a bit off topic but still. |
Bubble column with sprayFoam | dav.dap83 | OpenFOAM Running, Solving & CFD | 18 | November 30, 2020 15:06 |
Using sprayFOAM on cyclic problem with wedge boundaries | Mentalo | OpenFOAM Running, Solving & CFD | 5 | September 7, 2018 03:12 |
