updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() |
October 1, 2014, 22:40 |
yaqing
Rep Power: 12 |
Hi, everyone:
I am trying to run dynamic mesh case in pimpleDyMFoam, but after running one step, I always encounter this problem: updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient Does anyone meet similar problems before? Thank you very much. |
December 10, 2014, 04:08 |
Anthony DeFilippo
Are you using a type fixedFluxPressure for a pressure boundary condition? Maybe try switching to a zeroGradient boundary condition in pressure and see if the error goes away. Good luck |
July 16, 2015, 09:11 |
Przemek
Rep Power: 16 |
Thanks it helped.
best regards pblasiak |
October 28, 2015, 08:01 |
Simon Braungardt
I have the same problem in simpleFoam. Using zeroGradient works.
But my case is that I want to simulate the pressure drop in a bifurcation of tubes with a given massflow through the tube. So, as far a I understand fixedFluxPressure is the boundary condition I should use. How can I fix the case to use fixedFluxPressure? |
June 25, 2021, 05:49 |
Kennedy Murithi Micheni
Rep Power: 6 |
Did you solve this?
June 25, 2021, 06:40 |
Rep Power: 6 |
I am in the same problem with fixedFluxPressure boundary conditions but changing the BC to zeroGradient does not work still
December 14, 2021, 10:29 |
Rep Power: 7 |
Hello. I've the same error problem here with ofv2106.
inlet { type fixedFluxPressure; value uniform 0; } outlet { type PrimalPressureOutlet; p0 uniform 0.; } paroiAdiabatique { type fixedFluxPressure; value uniform 0; } paroiChaude { type fixedFluxPressure; value uniform 0; }
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. » |
March 14, 2024, 12:57 |
Raphael Santos
Rep Power: 13 |
An old post, but, check if you wrote fixedFluxPressure in another propertie, as velocity or temperature, etc.
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
updateCoeffs() and evaluate() | lixx | OpenFOAM Programming & Development | 11 | August 12, 2020 16:41 |
terminate called after throwing an instance of 'int' | b614910 | SU2 | 10 | July 27, 2014 23:16 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
