Oscillating behaviour when mesh gets too small |
January 9, 2014, 06:04 |
James B
Rep Power: 13 |
Dear Foamers
I am simulating detonations with a 2nd order approximate Riemann Solver. The results are smooth when I have a relative coarse mesh size of 1 mm but when I refine my mesh the solver starts to oscillate in every variable (see figure), would you have any idea on how to solve this problem or where it comes from ? (Maybe adapting the FVScheme and add more dissipation)? The mesh is a 1D shocktube (1 cell with upper and lower BC symmetry conditions imposed) Thank you very much!! Here is the FvScheme from DDTFoam Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(scalarSlope) cellMDLimited Gauss linear 1; grad(USlope) cellMDLimited Gauss linear 1; } divSchemes { default none; div(tauShear) Gauss linear; div(tauMC) Gauss linear; div((tauShear&U)) Gauss linear; div((p*U)) Gauss linear; div((U+((sL*Xi)*-grad(c)))) Gauss linear; div((sL*grad(b))) Gauss linear; div(U) Gauss linear; div((sL*-grad(c))) Gauss linear; div(phiSt,c) Gauss vanLeer01; div(phiXi,Xi) Gauss vanLeer; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,omega) Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default none; interpolate(tauMC) Gamma phi 1.0; interpolate(mu) Gamma phi 1.0; interpolate(muEff) Gamma phi 1.0; reconstruct(rho) limitedLinear 1.0; reconstruct(U) limitedLinearV 1.0; reconstruct(T) limitedLinear 1.0; interpolate(rho) linear; // for CFL reconstruct(cSound) linear; // for CFL interpolate(p) linear; // for MinMax scheme interpolate(Teff) linear; // for MinMax scheme interpolate(tau) linear; // for MinMax scheme interpolate(-grad(c)) linear; interpolate(grad((1-c))) linear; interpolate((((p*psiu)*sL)*Xi)) linear; interpolate((sL*((1|Xi)-Xi))) linear; interpolate(((rhoUnburned*sL)*Xi)) linear; interpolate((laplacian(interpolate(alphaEff),c)|mag(-grad(c)))) linear; } snGradSchemes { default corrected; } |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Gambit: mesh size to small??? | Ralf Schmidt | FLUENT | 1 | January 28, 2006 02:26 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
