Cannot run as parallel. please help.
Old   October 21, 2013, 08:27
Default Cannot run as parallel. please help.
Tommi P. Laiho
TommiPLaiho is on a distinguished road
I am making car simulation and I would like to use 2 cores. I have 8 cores at use, four cores in each Intel Xeon processor.
However when I try to run the simulation as parallel I will get this kind of error:
[0] --> FOAM FATAL IO ERROR:
[0] cannot find file
[0]
[0] file: /home/tommi2/OpenFOAM/tommi2-2.1.1/run/processor0/0/p at line 0.
[0]
[0] From function regIOobject::readStream()
[0] in file db/regIOobject/regIOobjectRead.C at line 73.
[0]
FOAM parallel run exiting
[0]
Reading field p
[1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] cannot find file
[1]
[1] file: /home/tommi2/OpenFOAM/tommi2-2.1.1/run/processor1/0/p at line 0.
[1]
[1] From function regIOobject::readStream()
[1] in file db/regIOobject/regIOobjectRead.C at line 73.
[1]
[1]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 20669 on
node caelinux exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[caelinux:20668] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[caelinux:20668] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Please let me know what to do. Thank you!
PS. I use this code to run the simulation:
mpirun -np 2 pisoFoam -parallel
TommiPLaiho is offline   Reply With Quote
Old   October 21, 2013, 08:49
Bernhard
Bernhard is on a distinguished road
Are you sure it works serial? i.e, does pisoFoam give you any errors? In any case, the 0/p file is missing or your decomposition went wrong. You can read this from the error message.
Bernhard is offline   Reply With Quote
Old   October 21, 2013, 09:05
Tommi P. Laiho
No I am not sure whether or not it works as serial. Furthermore I do not understand a lot what the OpenFOAM says. I am a newbie in this business.
I think that "p" in 0 folder is not missing. So something went wrong with the decomposition?
Here is the result when I run only:
pisoFoam
And it produces:
Reading field p
cannot find file
file: /home/tommi2/OpenFOAM/tommi2-2.1.1/run/0/p at line 0.
FOAM exiting
and here is my "p" file:
| \\ / F ield | OpenFOAM Extend Project: Open Source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
#include "initialConditions"
dimensions [0 2 -2 0 0 0 0];
internalField uniform $pressure;
boundaryField
"inlet|ground|ahmed_.*"
{ type zeroGradient;}
outlet
{type fixedValue;value $internalField;}
"sides|top"
{ type symmetryPlane;}
Please let me know how to fix "p"-file. Many thanks!
Old   October 21, 2013, 09:07
Bernhard
You are running from .../run/, and there is no .../run/0/p. That is certain by the errormessage. You don't want to cd into a specific case directory?
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 15:43
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 14:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
