Adaptive Mesh refinement for steady state solver |
July 17, 2013, 13:35 |
#1 | |
Haomin Yuan
Rep Power: 14 |
Hey, all,
I have a problem about adaptive mesh refinement. I looked around all the solver, it seems all the solver that can do AMR is transient solver. Does anyone know if there is a existing AMR steady solver? I also tried to implement AMR into rhoSimplecFoam solver. The procedure was simple, but I met error. I added mesh.update() in the solver. The error info is : Quote:
thank you in advance~ |
July 18, 2013, 01:55 |
Akshay Kumar
Rep Power: 16 |
Hey!
Is your cacheAgglomeration off? Try that. |
July 18, 2013, 12:07 |
Haomin Yuan
Rep Power: 14 |
Yes, this is the problem. I worked it out.
thank you |
August 20, 2013, 04:11 |
Dear Haomin,
Did you just add mesh.update() in your solver? Is it sufficient to have adaptive mesh refinement for any steady state solver? Regards, Hossein |
August 20, 2013, 11:47 |
Haomin Yuan
Rep Power: 14 |
Hi, you also have to use "dynamicMesh" class to construct mesh. You can easily find examples in solvers that used dynamicMesh.
And, yes, the sentence that make difference is "mesh.update()". |
April 12, 2017, 07:35 |
Jeroen
Rep Power: 10 |
I'm also trying to implement adaptive meshing in my simpleFoam solver, but I seem to get the following error when I include mesh.update(); in my Simple Loop. error: 'class Foam::fvMesh' has no member named 'update' I've been trying to look at pimpleDyMFoam and use this as a starting point for my simpleFoam solver. Any ideas how I can tackle this problem? |
Adding adaptive mesh refinement to the forwardStep tutorial | AlphaSheep | OpenFOAM Running, Solving & CFD | 10 | August 3, 2019 15:40 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 04:59 |
adaptive mesh refinement in STARCCM+ | abdullahkarimi | Siemens | 1 | November 16, 2010 19:26 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Mesh generator and CFD solver | Gennady Kireyko | Main CFD Forum | 0 | May 6, 2001 12:13 |
