Parallel motorBike LES computing problem.
Old   August 20, 2012, 10:57
Unhappy Parallel motorBike LES computing problem.
Jie Chen
xiexiehezuo is on a distinguished road
I ran the pisoFoam LES motorBike tutorial case on the cluster. It worked fine. Using the default setup, this job finished in about 7 hours on 8 cores. However, after I change a few parameters, it gets stuck at the step pisoFoam for 32 cores.
Basically, I changed the decompose method in the decomposeParDict to be scotch and increased the numberofSubdomains to be 32. Then, changed a few lines of Allrun in the lesfiles folder to use the RAS solution from 8 cores as the initial condition and then ran LES on 32 cores.
runApplication reconstructParMesh -constant -mergeTol 1e-6
rm -rf processor*
# Set-up the LES case
rm -rf 0/
mv 500/ 0/
rm -rf 0/uniform/
cp system/decomposeParDict.scotch system/decomposeParDict
runApplication decomposePar
cp ../lesFiles/fvS* ../lesFiles/controlDict system/
cp ../lesFiles/LESProperties ../lesFiles/turbulenceProperties constant/
cp ../lesFiles/nuSgs 0/
#ls -d processor* | xargs -i rm -rf ./{}/0/uniform $1
ls -d processor* | xargs -i cp ../lesFiles/LESProperties ./{}/constant/ $1
ls -d processor* | xargs -i cp ../lesFiles/turbulenceProperties ./{}/constant/ $1
ls -d processor* | xargs -i cp ../lesFiles/nuSgs ./{}/0/ $1
runParallel pisoFoam 32
I don't know what is wrong here. Can anybody help me?
xiexiehezuo is offline   Reply With Quote
Old   August 22, 2012, 17:44
Jie Chen
I figured out this problem. The reason is just the different run environment on the cluster. I changed the script. Now, it works fine.
Parallel interDyMFoam cellLevel problem tgvosk OpenFOAM Running, Solving & CFD 5 February 19, 2014 03:24
Parallel processing problem newbie29 OpenFOAM Running, Solving & CFD 1 June 22, 2012 05:23
problem!! FLUENT 6.2 -SUSE parallel computing khanjaved FLUENT 1 August 15, 2005 23:00
Problem using parallel Fluent Gustavo FLUENT 0 June 28, 2004 00:12
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
