do i need to compile after changing a .h file |
February 9, 2012, 03:33 |
tomek
Rep Power: 14 |
hello,
i have to change the constants in the calculation for kappa (thermal conductivity) in: kappa ( const scalar T ) const { scalar Cv_ = this->Cv(T); return mu(T)*Cv_*(1.32 + 1.77*this->R()/Cv_); which is calculated in sutherlandTransportI.H. I need to do this to get a thermal conductivity i can compare with the one i get in fluent. now i wanted to know if i have to compile the code or if it is not needed when changing .H-Files? greetz tomek |
February 9, 2012, 08:30 |
Laurens Van Dyck
Rep Power: 15 |
Any change in source code (including *.h header files) need to be recompiled
February 9, 2012, 10:44 |
tomek
Rep Power: 14 |
thank you....
now i have another problem... due to backup reasons i had to copy the complete "openfoam201" folder and now have to use the copied, renamed "openfoam_update" where i can make the changes... now i started to enter the changes in the header file and to fix the .bashrc entries... after that i wanted to compile with ./allwmake but i got the message: Error: Current directory is not /opt/openfoam201 Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. do u know what else do i have to change...or did i miss another .bashrc?! |
February 9, 2012, 10:50 |
Laurens Van Dyck
Rep Power: 15 |
Either you miss some changes in your bashrc (what output do you get if you type "$WM_PROJECT_DIR" in terminal?) or you are still loading your old bashrc instead of the new one which you are editing. Check this by seeing if you link to the correct openfoam bashrc file in your linux bashrcfile (> gedit ~/.bashrc , does it have a line similar to . /opt/openfoam201/etc/bashrc or . /opt/openfoam201_update/etc/bashrc in it?)
February 9, 2012, 11:08 |
tomek
Rep Power: 14 |
thank you for the fast answer...
when i edit "$WM_PROJECT_DIR" i get : bash: /opt/openfoam201: is a directory as answer... so i guess its still the wrong bash... i am working with caelinux, so in my bashrc file there is: . /opt/.bashrc-CAE, - there i changed all entries to openfoam_update... but i think i found the problem there...in my openfoam_update/etc/.bashrc there is the line: # Location of installation # ~~~~~~~~~~~~~~~~~~~~~~~~ export WM_PROJECT_INST_DIR=$FOAM_INST_DIR export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/openfoam201 do i have to change this? i am a bit afraid of killing it all.... |
February 10, 2012, 02:47 |
Laurens Van Dyck
Rep Power: 15 |
You don't "edit" a system variable, you declare it in your bashrc. Inside your /opt/.bashrc-CAE file, it should reference your openfoam_update/etc/.bashrc i suppose? Make sure it does not reference openfoam/etc/.bashrc. Afterwards you still have to edit your openfoam_update/etc/.bashrc such that they all use the new location as visible in the last part of your post. So yes, you need to edit that too
Just some advice for later, before you start editing your system bashrc on so many levels make a backup first |
February 10, 2012, 02:52 |
tomek
Rep Power: 14 |
ok i changed the line now...
then i entered: foamuser2@foamuser2:~$ $WM_PROJECT_DIR and got the message: bash: /opt/openfoam_update/openfoam_update: is a directory foamuser2@foamuser2:~$ but when i start the terminal cae-terminal, then there is the message: bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory is there still something missing? |
February 10, 2012, 03:33 |
Laurens Van Dyck
Rep Power: 15 |
Double check if you put the right information in. Your $WM_PROJECT_DIR (dont worry if it says its a directory, it should be that ) refers to /opt/openfoam_update/openfoam_update and not /opt/openfoam_update/
Change it in the bashrc to the correct directory and test if it worked (and if the directory exists) by typing: > cd $WM_PROJECT_DIR |
February 10, 2012, 03:50 |
#9 |
tomek
Rep Power: 14 |
hey...
thank you so much for your help... sorry when there are some strange questions- its my first time i am doing something like that... by reading my posts i guess you can imagine how confused i am.... i think a backup would have been a good idea...but now there is no way back...it has to work... ok..you were right - the directory i wrote was wrong...i corrected it and it worked - i directly came to opt/openfoam_update... but when i start a new terminal- there is still: bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory bash: Error: No such file or directory bash: :: No such file or directory bash: unknown/unsupported: No such file or directory bash: naming: No such file or directory bash: convention: No such file or directory i am not sure about the terminology- but do i have to compile my changes to get caelinux understand i changed some directories? |
February 10, 2012, 04:21 |
#10 |
Laurens Van Dyck
Rep Power: 15 |
No this must be still some errors in your CAE or OpenFoam bashrc.
Check these two files for the words which you see in the error message (unknown/unsupported/naming/convention...). I dont have cae linux so I cant check for my self unfortunately. |
February 10, 2012, 07:28 |
#11 |
tomek
Rep Power: 14 |
i ve been searching for a long time and didnt find anything, so I decided to turn the things around and called my folder openfoam201 and the other of201_original...
this way after declaring my system variables in the bashrc's it works...?!? so now back to my first question: i've changed the header file - do i have to compile by using gcc or by using the make-files? |
February 10, 2012, 09:05 |
#12 |
tomek
Rep Power: 14 |
i tried to compile the part where i changed the header file by using ./Allwmake
now the problem is: when i run it as 'normal' user he starts to run but the messages he is entering are like: ... mkdir: cannot create directory `linux64GccDPOpt': Permission denied /bin/sh: linux64GccDPOpt/options: No such file or directory make[2]: *** [linux64GccDPOpt/options] Error 1 /opt/openfoam201/wmake/MakefileFiles:40: linux64GccDPOpt/options: No such file or directory make[2]: *** No rule to make target `linux64GccDPOpt/options'. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /opt/openfoam201/applications/solvers/stressAnalysis/solidDisplacementFoam make[1]: *** [solidDisplacementFoam] Error 1 mkdir: cannot create directory `linux64GccDPOpt': Permission denied /bin/sh: linux64GccDPOpt/options: No such file or directory make[2]: *** [linux64GccDPOpt/options] Error 1 /opt/openfoam201/wmake/MakefileFiles:40: linux64GccDPOpt/options: No such file or directory make[2]: *** No rule to make target `linux64GccDPOpt/options'. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /opt/openfoam201/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam make[1]: *** [solidEquilibriumDisplacementFoam] Error 1 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/opt/openfoam201/applications/solvers/stressAnalysis' make: *** [stressAnalysis] Error 2 make: Target `application' not remade because of errors. so i thought it might be a permission reason and tried it as sudo: ./Allwmake: line 4: wmakeCheckPwd: command not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. so again it is something with my bash-files? |
February 10, 2012, 09:43 |
#13 |
Laurens Van Dyck
Rep Power: 15 |
I suppose the openfoam folder is owned by the administrator such that only someone with admin rights can compile, however it is very likely that sudo wont work since wmake is only accessible to you as a user. I would suggest to change the owner of the openfoam folder to yourself instead of admin (chown -R yourname:\ /opt/openfoam) and try to compile again.
February 10, 2012, 11:34 |
#14 |
tomek
Rep Power: 14 |
yes...its running....thank you so much!
have a nice weekend.... |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
