OpenFOAM - Implement Change To Modelled Term Reynolds Stress Models (LRR & SSG) |
February 14, 2024, 07:22 |
#22 | |
ASR
Rep Power: 3 |
OpenFOAM failing to compile LRR and outputting error message
February 14, 2024, 07:39 |
#24 |
ASR
Rep Power: 3 |
LRR.C is already compiled in the source code, I need to compile a new LRR model. Changing the name from LRR.C to myLRR.C shouldn't be the root cause of the issue because I've done the same for kOmega.C to mykOmega.C with zero incidence.
February 14, 2024, 07:52 |
#25 |
ASR
Rep Power: 3 |
Okay I appear to have resolved the compilation issue but I'm unsure why.
In the .H file, I commented out the final few lines Code:
//#ifdef NoRepository // #include "myLRR.C" //#endif Code:
wmake libso . wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file mykinematicMomentumTransportModels.C g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude -fPIC -c mykinematicMomentumTransportModels.C -o Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o -L/home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib \ -ltransportModels -lmomentumTransportModels -lfiniteVolume -lmeshTools -o /home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib/mykinematicMomentumTransportModels.so |
February 14, 2024, 08:01 |
#26 |
Your goal is clear to me.
The way you reason about reaching that goal is *not* yet entirely clear to me. The compiler tells you that it is looking for the symbol bound.o. It is therefore likely that when compiling myLRR.C, some header files (*.H files) are missing. Four questions thus emerge: 1/ what header files are required to compile the original unmodified LRR.C file? 2/ does the command "nm -g LRR.o" show the presence of the symbol LRR.o? 3/ are the files LRR.C and myLRR.C the same? 4/ how do the compilation of LRR.C and myLRR.C differ? Good luck. Domenico. Last edited by dlahaye; February 14, 2024 at 08:03. Reason: Pls ignore this message. Issue resolved. Congrats! |
February 14, 2024, 08:11 |
#27 |
ASR
Rep Power: 3 |
No worries just seen your edit. Yeah it appears someone has already tried this approach before with compilation issues, i.e., error message in terminal, and has resolved them. Please refer to video by trushar gobil, minute 19:55 https://www.youtube.com/watch?v=kfsh...t_aqf&index=14 |
February 14, 2024, 09:21 |
#28 |
ASR
Rep Power: 3 |
Okay,
Now I'm trying to run the new LRR model (without modifying code) to see if it works. I get the following error message: Code:
simpleFoam: symbol lookup error: /home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib/libsimpleLRRMomentumTransportModels.so: undefined symbol: _ZN4Foam9RASModels9simpleLRRINS_36IncompressibleMomentumTransportModelINS_23kinematicTransportModelEEEEC1ERKNS_17geometricOneFieldES8_RKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS9_IdNS_13fvsPatchFieldENS_11surfaceMeshEEESL_RKS3_RKNS_4wordE |
February 14, 2024, 12:59 |
#29 |
Rep Power: 14 |
Very strange - I have just tested it on my implementation (Foundation, v8) and it works fine - I didn't have to comment out the lines that you highlighted. Must be a problem with v9. Can you use v8?
PS - just in passing - I note that you are editing your version of the LRR models etc in the OF distribution folder, rather than under your user directory. This is really dangerous, since you can unwittingly overwrite something in the OF distribution. I'd strongly suggest you using the USER folder ... i.e. create $FOAM_RUN/../src, $FOAM_RUN/../applications and compile any libraries and apps into $FOAM_LIBBIN and $FOAM_APPBIN. Your choice though. |
February 14, 2024, 13:22 |
#30 |
ASR
Rep Power: 3 |
Thank you for the suggestions! I thought I was modifying the code in the user directory as I pulled all the relevant files (.C .H, Make, etc) in a separate folder where I run all my simulations and not the src file in the OpenFOAM folders Also, could I have access to your setup? I want to see if I can get it to run on OPENFOAM-9. |
February 14, 2024, 13:26 |
#31 |
Rep Power: 14 |
Aaah okay - then it's just that you are dumping your final library in the distribution folder. My Make/files is:
myKinematicMomentumTransportModels/myKinematicMomentumTransportModels.C LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleMomentumTransportModels Code:
EXE_INC = \ -I../momentumTransportModels/lnInclude \ -I$(LIB_SRC)/transportModels/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/incompressible/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/incompressible/kinematicMomentumTransportModels \ LIB_LIBS = \ -lincompressibleTransportModels \ -lmomentumTransportModels \ -lfiniteVolume \ -lmeshTools |
February 14, 2024, 14:50 |
#32 |
ASR
Rep Power: 3 |
I've tried out with your set-up. It doesn't appear to work for me at all. I appreciate your help, just seems to be going wrong for me for some reason. |
February 15, 2024, 08:28 |
#33 |
ASR
Rep Power: 3 |
I've tried it out with OpenFOAM-10 using the same strategy. Find the same situation where mykOmega or mykEpsilon compiles perfectly and myLRR or mySSG fail to compile.
February 15, 2024, 09:47 |
#34 |
ASR
Rep Power: 3 |
I've even tried other models such as LaunderSharmaKE which also work fine. It seems OpenFOAM can compile anything but the LRR and SSG models.
Compilation: Code:
wmake libso . wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file mykinematicMomentumTransportModels.C g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude -fPIC -c mykinematicMomentumTransportModels.C -o Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o -L/home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib \ -ltransportModels -lmomentumTransportModels -lfiniteVolume -lmeshTools -o /home/cfd/OpenFOAM/cfd-9/platforms/linux64GccDPInt32Opt/lib/mykinematicMomentumTransportModels.so Code:
EXE_INC = \ -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \ -I$(LIB_SRC)/MomentumTransportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ LIB_LIBS = \ -ltransportModels \ -lmomentumTransportModels \ -lfiniteVolume \ -lmeshTools Code:
mykinematicMomentumTransportModels.C LIB = $(FOAM_USER_LIBBIN)/mykinematicMomentumTransportModels |
February 16, 2024, 08:51 |
#35 |
ASR
Rep Power: 3 |
Appear to have resolved issue. Spoke to someone with experience in modifying source code for OpenFOAM. For myLRR.C file had to include a bound.C file in order to successfully compile.
#include "myLRR.H" #include "fvModels.H" #include "fvConstraints.H" #include "wallDist.H" #include "bound.C Code:
SIMPLE: Convergence criteria found U: tolerance 1e-05 p: tolerance 1e-05 k: tolerance 1e-05 epsilon: tolerance 1e-05 R: tolerance 1e-05 omega: tolerance 1e-05 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model myLRR RAS { model myLRR; turbulence on; printCoeffs on; couplingFactor 0; Cmu 0.09; C1 1.8; C2 0.6; Ceps1 1.44; Ceps2 1.92; Cs 0.25; Ceps 0.15; wallReflection true; kappa 0.41; Cref1 0.5; Cref2 0.3; } Creating MRF zone list from MRFProperties creating MRF zone: SRF No fvModels present No fvConstraints present Starting time loop |
#36 |
Rep Power: 14 |
Well, I can confirm that I get the same error message as you (complaining about bound being out of scope) in my implementation of v10, so it's not your setup that is at fault.
I spent 10mins looking at this and managed to get LRR to compile with the simple expedient of adding: Code:
#include "bound.H" |
February 16, 2024, 08:52 |
#37 | |
Rep Power: 14 |
February 16, 2024, 10:48 |
#38 |
ASR
Rep Power: 3 |
Hi Tobermory,
I want to thank you and dlahaye so much for your patience. I have managed to get simpleLRR (changed name from myLRR) to run with my modifications. It was really simple, all I did was simplify DREff() and DepsEff() based on this paper by Lien & Leschnizer (1994) https://doi.org/10.1016/0045-7930(94)90001-9. The new terms are Code:
template<class BasicMomentumTransportModel> tmp<volScalarField> simpleLRR<BasicMomentumTransportModel>::DREff() const { return volScalarField::New ( "DREff", (this->nut_/sigmak_ + this->nu()) ); } template<class BasicMomentumTransportModel> tmp<volScalarField> simpleLRR<BasicMomentumTransportModel>::DepsilonEff() const { return volScalarField::New ( "DepsilonEff", (this->nut_/sigmaEps_ + this->nu()) ); } |
February 16, 2024, 10:50 |
#39 |
Rep Power: 14 |
Well done!
February 16, 2024, 10:54 |
#40 |
ASR
Rep Power: 3 |
My only one uncertainty is the terminal spits out the following warning when doing a parallel run (serial run no warning shows up):
--> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1247 dlopen error : /home/cfd/OpenFOAM/cfd-9/platforms/linux64GccDPInt32Opt/lib/libsimpleLRRMomentumTransportModels.so: undefined symbol: _ZTIN4Foam36incompressibleMomentumTransportModelE --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 106 could not load "libsimpleLRRMomentumTransportModels.so" |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
STATEMENT about how to implement new turbulent models in OpenFOAM | PeterShi | OpenFOAM Running, Solving & CFD | 0 | February 28, 2017 08:18 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
Reynolds Stress Model in OpenFOAM | harsha_kulkarni | OpenFOAM Pre-Processing | 0 | August 3, 2014 03:23 |
How the trace term of SGS stress tensor implemented in Openfoam | star shower | OpenFOAM Running, Solving & CFD | 0 | March 3, 2012 09:56 |
