Error while solving for trans-critical fluid flow of N2
Old   September 5, 2021, 04:11
Unhappy Error while solving for trans-critical fluid flow of N2
swapnil
sopu is on a distinguished road
I am trying to simulate transcritical/supercritical flow of N2.
I am using nasa9 polynomials and transport properties for dense fluids by Chung et al.
I have successfully simulated supercritical flow(T=137K,P=4Mpa) but when I try to go near transcritical region (T=127K,P=4Mpa), the newton rhapson method which calculates temperature back from solved enthalpy fails.
I am attaching the error message here.
https://drive.google.com/file/d/149R...ew?usp=sharing
I have tried few suggestions from FOAM FATAL ERROR Maximum number of iterations exceeded but it doesn't work. This new solver keeps crashing within few minutes.
Please give suggestion to solve this problem.
sopu is offline   Reply With Quote
Old   November 22, 2021, 02:06
Default Solved this issue by changing algorithm
swapnil
I have changed the root finding algorithm to bisection method and it works now. But it is quite slow due to nature of bisection method.
newton-raphson, supercritical n2, transcritical
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
