Kinematic cloud properies the meainig of the terms |
February 23, 2016, 08:29 |
Manu Chakkingal
Rep Power: 10 |
Hello
I am trying to simulate bubble column with a combination of interfoam and kinematic cloud parcels (for bubble parcels). I came across the properties model1 { type patchInjection; massFlowRate .000072; massTotal .0072;// SOI 0; nParticle 10; //is this the no. of particles in a parcel parcelBasisType fixed; patchName inlet; parcelsPerSecond 1e2; duration 20; U0 (0 2 0);//is this the velocity of parcels at inlet flowRateProfile constant 1; sizeDistribution { type RosinRammler; RosinRammlerDistribution { minValue 5e-3; maxValue 5e-3; d 5e-3; n 3; } } } } How is the mass flow rate determined for the parcels injected. What is the density used for calculation of the mass flow rate. is the volume flow rate (before multiplication with density to calculate mass flow rate) determined by using the velocity U0 in the above list times the area of inlet patch..Then what is the role of the diameter of particles specified in the distribution. |
Error during reconstructing lagarangian fields | ybapat | OpenFOAM | 9 | November 17, 2014 08:52 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 08:53 |
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com | Markus Schmidberger | OpenFOAM Announcements from Other Sources | 0 | July 26, 2011 09:18 |
Question in definition of terms in solve | titio | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 17:02 |
K-Epsilon model? | Brindaban Ghosh | Main CFD Forum | 2 | June 24, 2000 05:22 |
