Cell-wise heatFlux?
Old   February 26, 2015, 13:04
Question Cell-wise heatFlux?
Bernhard Linseisen
Linse is on a distinguished road
Dear all,
I would like to analyse the integral heatflux into or from cells within flow domains within rhoReactingBuoyantFoam. This would allow to find out if and where the flow is surpassing a certain activation energy.
While this seems well possible for walls (wallHeatFlux-condition), I did not yet find a way to implement it for internal cells...
I guess the problem is divided in two:
1. How does one read the heatflux across an internal face?
2. How does one sum up all of the heatfluxes across the faces of one cell?
Thanks for any answers already in advance!
Cheers,
Bernhard
Linse is offline   Reply With Quote
Old   February 27, 2015, 05:31
anonymous
ssss is on a distinguished road
You can access each cell faces, and then calculate the heatFlux as in the wallHeatFlux app, with some modifications :
surfaceScalarField heatFlux
     fvc::interpolate
             turbulence.valid()
             ? turbulence->alphaEff()()
             : thermo->alpha()
      )*fvc::snGrad(h)
        forAll (mesh.cells(),cellI)
            const cell& faces = mesh.cells()[cellI];
            scalar sumHeatFlux=0;
            forAll( faces, i )        // loop over all faces in cellI
               sumHeatFlux+=mesh.magSf()[i]*heatFlux[i];
Let me know if it works I'm not sure of how you want to calculate the heatFlux
ssss is offline   Reply With Quote
Old   February 27, 2015, 11:09
Bernhard Linseisen
Dear ssss,
Thanks a lot for that quick reply!
I just tried to implement that. While compilation works, it does not provide anything different from 0 - which is kind of unrealistic in a flow where - just for test purposes - I put a temperature gradient of over 200 Kelvin.
So it seems somehow the value is not computed correctly - if at all.
Although I had to drop out the alphaEff for turbulence-model reasons, there should be a heat flux nevertheless.
At the moment I am trying to get a grasp on the different geometric fields in use via the Programmers' Guide, but any hints are welcome!
Cheers,
Bernhard
Old   February 27, 2015, 11:11
anonymous
Could you provide me a testcase to try it?
It may be 0 every where because I initizalized the variable inside a for-loop and thus it will be 0 outside.
Old   February 27, 2015, 11:34
Bernhard Linseisen
Simple testcase in preparation...
Old   March 13, 2015, 08:31
Default Testcase and Solver
Bernhard Linseisen
Okay, it took longer than expected (the flu didn't help, either), but now there are a minimal testcase for the question as well as a minimal solver based on rhoReactingBuoyantFoam. Unfortunately the file is too big, so you will have to download it from
http://blinseis.web.cern.ch/blinseis...luxFoam.tar.gz (approx. 3.3 Mb)
Afterwards just compile from within reactingFoam/rhoReactingBuoyantFoam and the solver should be available as rhoReactingBuoyantFoam_heatFlux_1 .
The strange thing for the moment:
Different heatFluxes are computed for the different cells. Too big to be negligible/numerical noise. This is expected.
Nevertheless the heatFluxes are in places where they are not expected at all, while other places with a definite heatFlux are very lowlevel.
Any Ideas? Thanks for your thoughts in advance!
heatflux, rhoreactingfoam
interFoam running blowing up sandy13 OpenFOAM Running, Solving & CFD 2 May 5, 2015 08:16
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
