Standard k-epsilon based Nonequilibrium turbulent viscosity model |
February 13, 2013, 03:23 |
Nikesh Bhattarai
Rep Power: 13 |
I have been trying to implement a non equilibrium turbulent viscosity model (Akira Yoshizawa et al.) into OpenFOAM. The turbulence quantities (k and epsilon) are governed by the same equations of the standard k-epsilon model.
At the moment I am trying to validate my code for the case of a 2D flat plate turbulent boundary layer and compare the results I've obtained using LaunderSharmaKE model. I could obtain the results but they are not making sense to me. I have attached here the equations of the model and the code that I have used. I also have included the results. I have as well made use of a low Reynolds-number corrections as proposed by Abe et al. I have included those equations too. I would be really thankful if someone with insights in this field looked into it and shed me some light in this matter. Thanks in advance!! Nikesh. |
February 13, 2013, 03:53 |
Result files
Nikesh Bhattarai
Rep Power: 13 |
The result file is attached here.
What I have done here is that I have limited the blending functions. 1. min(fMu,1) and min(sqr(Rt), 50) 2. fMu-limited, Rt-not limited 3. fMu-not limited, Rt-limited |
Power - Law Viscosity Model for Polymers | NickolasPl | OpenFOAM | 2 | August 12, 2011 09:26 |
Curvature Effects using the Standard K Epsilon Model | syler3321 | CFX | 2 | October 19, 2010 21:53 |
Reynolds transport, turbulence model, etc | Beginner | Main CFD Forum | 1 | January 7, 2009 06:36 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
