February 6, 2013, 03:57 |
Loop over cells slowing down the code
Guillaume
Rep Power: 13 |
Hi everybody,
I try to create a field for my variable alphath. The value I want to set for this variable depends on space. Finally, the algorithm should look like : For all cells If ( x < xmax and x > xmin) alphath = f(x) In order to go step by step in the coding process (I'm not really a senior coder in openFoam ...), for the moment, I just try to impose, for all cells, alphath(x,y,z) = x I coded this stuff like that : forAll (mesh.cells(),celli) { alphath[celli] = mesh.C().component(vector::X)()[celli]; } Adding these lines in the code REALLY slows it down ... As a simple test, I replaced "mesh.C().component(vector::X)()[celli]" by "1.0" and the code is quick again. Do you know why the added lines slow the code down ? Would you have an alternative coding ? Thanks in advance for your help. Guillaume |
February 6, 2013, 04:13 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Guillaume,
I have a small guess, since you are first extracting the x-coordinate from the cell centres and then you get the i'th index (checked the code and a new volScalarField is constructed). This actually means that you make a copy of all of the x-values every time you only need one; so in the end of the day you have a process, which scales with N^2 rather than N. This should be faster: Code:
forAll( alphath, celli ) alphath[celli] = mesh.C()[celli].x(); Code:
alphath.internalField() = mesh.C().component(vector::X); Niels |
February 6, 2013, 05:15 |
Guillaume
Rep Power: 13 |
Hey Niels,
thanks a lot for having taken some of your time for my problem ! Your answer was quick, detailed and (after a test just performed) very efficient ! Thanks again. Kind regards, Guillaume Last edited by Gloq; February 6, 2013 at 05:42. |
February 6, 2013, 05:25 |
Rep Power: 37 |
Good!
/ Niels |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 20:18 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 02:30 |
for loop inside a cell_loop? | MHDWill | FLUENT | 0 | September 26, 2007 22:24 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 16:57 |
