decomposePar error- undefined is not in
Old   February 17, 2022, 06:02
Default decomposePar error- undefined is not in
qutadah
qutadah.r is on a distinguished road
Hi, I am getting this error when decomposing my mesh, I believe it has to do with the mesh, because I changed it and then this error came up at decomposing the case..
Decomposing mesh region0
Create mesh
--> FOAM FATAL IO ERROR:
unspecified is not in enumeration:
5
coincidentFullMatch
noOrdering
rotational
translational
unknown
file: .INT_BLADE_1-SIDE-1.transform at line 88.
    From function Enum Foam::NamedEnum<Enum, nEnum>::read(Foam::Istream&) const [with Enum = Foam::coupledPolyPatch::transformType; unsigned int nEnum = 5u]
    in file lnInclude/NamedEnum.C at line 69.
FOAM exiting
Please advise, thanks!
qutadah.r is offline   Reply With Quote
decomposepar, pimplefoam, polymesh
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
Threaded decomposepar sqek OpenFOAM Pre-Processing 0 October 8, 2021 14:31
decomposePar error chia87 OpenFOAM Pre-Processing 1 May 28, 2017 16:23
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 09:57
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 06:27
