Map fields on bigger Mesh
Old   April 12, 2017, 19:28
Default Map fields on bigger Mesh
vcattoir is on a distinguished road
Hi foamers,
I am currently working on some LES of a nozzle with a big box behind it to be able to observe turbulence a the exit of the nozzle.
The setup is quite heavy but I have to use a larger box to see what happens a bit further. I do not have the cluster time to do the simulation all over and would like to reuse my previous results and just simulate a bit more, enough that the new zone is correct.
I tried using mapFields, consistently or not which maps correctly the data, where the previous zone is my results and the rest is 0 but the solver won't start (Floating point exception: 8) I guess the abrupt change is not good...
Also, I get some warnings by mapFields (about 300-400 ?)
--> FOAM Warning :
    From function void Foam::faceAreaWeightAMI<SourcePatch, TargetPatch>::interArea(const label, const label) const
    in file lnInclude/faceAreaWeightAMI.C at line 359
    Invalid normal for source face 9197 points 4((0.0538464 -0.015 0.02125) (0.05574 -0.015 0.02125) (0.05574 -0.015 0.0225) (0.0538464 -0.015 0.0225)) target face 5017 points 4((0.0815679 0.015 0.02125) (0.0815679 0.015 0.0225) (0.0842558 0.015 0.0225) (0.0842558 0.015 0.02125))
Is there a way to solve my problem ? I tried with setFields first but would not work.
Thanks
vcattoir
vcattoir is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 23:36
