February 25, 2017, 14:58 |
#81 |
Ahmad Habib
Rep Power: 12 |
Dear Tian
Can you please answer my questions |
February 7, 2021, 14:44 |
#82 |
Herpes Free Engineer
Rep Power: 13 |
hope the following link can be helpful as well: Age of Air Function Object
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 8, 2021, 08:55 |
#83 |
Tobias Holzmann
Rep Power: 52 |
One hint: the mean age of air is already implemented as object function in the Foundation version.
Off-Topic: Why do you set the diffusion to 1 and ignore the turbulent diffusivity? A diffusivity coefficient of 1 should be wrong here. Commonly, the diffusion mixing is based on the viscosity, so I would - at least - use the molecular viscosity of your fluid rather than 1 (as it is extreme large). Furthermore, I am not sure why a three year old thread is pushed up as there is no question anymore ? :P
Keep foaming, Tobias Holzmann |
February 8, 2021, 10:06 |
#84 | ||||
Rep Power: 13 |
DT = alpha_v * nu + alpha_t * nu_t `alpha_v` is 1, and `alpha_t` is 0, hence DT~nu (which is your suggestion) [I am more than happy to be proven incorrect]. Please note that there are different definitions of age of air metric in the literature (at least five to my review) since its introduction at 1981. Albeit slightly, each contradicts one another. Quote:
January 7, 2022, 06:51 |
#85 |
jingfu zhang
Hi Andersking,
Could you please explain how to use the attachment? Open it by using Fluent or CFD-post? Do I need to install Visual Studio? I am pretty new in this field so I am looking for help Looking forward to your reply! Thank you ! |
January 7, 2022, 15:18 |
#86 | |
Tobias Holzmann
Rep Power: 52 |
Just one hint. The comfort and age function objects are also available in the ESI version v2112
January 7, 2022, 17:35 |
#87 |
Rep Power: 13 |
Thanks for the contributions, Tobi!
Here are the links of the FOs: age and comfort for those who are interested.
November 8, 2022, 09:18 |
#88 |
gabriel rodrigues
Rep Power: 4 |
First, i'd like to thank you so much for your contribuition with this function implemented in OF!
My question is, what exactly is the value of the output of this function? I have simulated a room for 100s and when I go to paraView to see contours map of the age it shows values from 0 to 3500. My thought is that, on that instant, based on the velocity of each particle, is given as result the time in seconds that a particle takes from the inlet to get thar location. Is this right? Thanks once again. |
November 10, 2022, 12:00 |
#89 |
Tobias Holzmann
Rep Power: 52 |
If you are simulating 100s , the max value can only be 100s. I think you are not simulation 100s but 100 iterations -> steadyState.
The outcome of the age field is the time it takes to refresh the cell with new fresh air. Hence a value of 1000 would mean that the air stays there around 1000s.
November 11, 2022, 06:51 |
#90 |
gabriel rodrigues
Rep Power: 4 |
Thank you for your reply!
I see. I'm running a simulation from 0 to 100s with a delta t of 0.01, thus 10000 iterations. The only thing is that i'm using pisoFoam algorithm (transient). In paraview displays a range of age from 0 to 3500, how could be this possible? Even if I'm running pisoFoam, could paraview be displaying the number of interation instead of seconds by default? |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
local age of air in starccm+ | Mike23 | Siemens | 3 | September 20, 2008 12:16 |
[Indoor Air Quality]How do I calcauate "Age of Air | Young | CFX | 6 | April 29, 2008 00:14 |
age of air | teddy | Siemens | 3 | February 9, 2007 10:41 |
Age of Air In Star-CD | Ted Crilly | Siemens | 1 | February 19, 2005 20:50 |
