Yesterday, 13:33 |
static pressure coefficient
Lars Hansen
In order to validate the flow around an airfoil I need to calculate the static pressure coefficient at several locations. How can I do this within Openfoam, using pressure functions. I don't understand how to set it up correctly. Thanks! |
Today, 06:45 |
Yann
Rep Power: 28 |
Hello Lars,
You can use the pressure function object to compute the static pressure coefficient. This will compute a new variable. The exact setup may vary depending on which OpenFOAM branch/version you are using:
Then you can use the probes function object to retrieve the values on the desired locations. Or use the sampling functions to extract it along a line, etc... Regards, Yann |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 21:05 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 16:00 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 01:11 |
