Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Bug or feature in wallHeatFlux calculation for patches??
Old   April 6, 2020, 09:14
Default Bug or feature in wallHeatFlux calculation for patches??
DaveD! is on a distinguished road
In OpenFoam v7, one can give the wall patches for which the wallHeatFlux field shall be calculated, otherwise wallHeatFlux is calculated for all wall patches.
wallHeatFlux //funktioniert!!!
    type wallHeatFlux;
    libs ("libfieldFunctionObjects.so");
    patches ("wall_heated");
    writeControl writeTime;
In postprocessing/wallHeatFlux/0/wallHeatFlux.dat, OpenFoam writes the min/max/integral values of the patch "wall_heated" as it should.
However, in the volScalarField that is created for each writeTime, wallHeatFlux is calculated for arbitrary patches, no matter which patches are being specified for calculation. In my case, wallHeatFlux was calculated for wall_heated and for inlet, the latter of which is purely non-sense.
Obviously, wallHeatFlux loops for the field creation over all boundaries and not the ones being specified (wallHeatFlux.C, line 87 f.):
    forAll(wallHeatFluxBf, patchi)
In contrast, wallShearStress does what it should (wallShearStress.C, line 79 ff.):
    forAllConstIter(labelHashSet, patchSet_, iter)
        label patchi = iter.key();
Is this a bug or a feature in wallHeatFlux?
Regards, DaveD!
DaveD! is offline   Reply With Quote
Bug in wall distance calculation david OpenFOAM Bugs 3 March 15, 2011 10:32
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Calculation of heat transfer coefficients uli_u OpenFOAM Running, Solving & CFD 16 November 25, 2009 11:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
Warning 097- AB Siemens 6 November 15, 2004 05:41
