Plot part of mesh on surface elevation filter |
January 14, 2016, 19:26 |
Maxim Van Zonhoven
Rep Power: 11 |
Recently I have been trying to simulate a wave field past a fixed cylinder. I would like to give the surface elevation on a figure with the cylinder also clearly visible. By applying a contour and calculator filter I succeeded in plotting the surface elevation itself (attach.). Is it possible to add the actual cylinder in this figure? It seems I can not just make the internal mesh invisible because my filters rely on this part of the mesh to be visible. Thanks in advance. Regards, Maxim |
January 15, 2016, 14:34 |
Davi Barreira
Rep Power: 12 |
I assume you are using Paraview. In the same file that you are working in paraview, press the "open" and select your case file again (your .foam file in the case folder). Once you do that, you will have two identical files, but now you may superpose them. So in one of them you do all your filtering to show the wave, and in the other you leave it be, that way you will see the cylinder.
(there are many different ways to do this) |
January 15, 2016, 19:23 |
Maxim Van Zonhoven
Rep Power: 11 |
This works very well.
Thank you very much! Maxim |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
