libsampling for DyM solver exporting vtk patch. Problem to update geometry |
July 7, 2015, 05:11 |
M. Montero
Rep Power: 17 |
Hi all,
I am simulating a case with pimpleDyMFoam and I want to export vtk files while simulation is running. The following code is included inside the controlDict file. Vtk files are written but only fields information is updated. Geometrical information is not updated so the blade1 is frozen in space when opening the files in paraview. I want to make an animation so I need real position of the patch for that. Code:
surfaces { type surfaces; // Where to load it from (if not already in solver) functionObjectLibs ("libsampling.so"); // outputControl outputTime; outputControl timeStep; outputInterval 1; surfaceFormat vtk; fields ( p U); interpolationScheme cell; //cell cellPoint cellPointFace surfaces ( blade1 { type patch; patchName blade1 ; interpolate false; needsUpdate false; } Code:
//- Does the surface need an update? virtual bool needsUpdate() const; //- Mark the surface as needing an update. // May also free up unneeded data. // Return false if surface was already marked as expired. virtual bool expire(); //- Update the surface as required. // Do nothing (and return false) if no update was needed virtual bool update(); Thank you very much. Last edited by be_inspired; July 7, 2015 at 07:46. |
October 9, 2015, 05:22 |
libsampling with moving walls using pimpleDyMFoam. Position is not updated
M. Montero
Rep Power: 17 |
I am running the axial turbine tutorial using the following lines in the control Dict to write the vtk files while runing and so, make a video of the turbine rotating.
The problem is that the geometry is fixed although the variables are updated. How can the geometrical information be updated also? Thank you very much Code:
functions ( surfaces { type surfaces; // Where to load it from (if not already in solver) functionObjectLibs ("libsampling.so"); // outputControl outputTime; outputControl timeStep; outputInterval 1; surfaceFormat vtk; fields ( p U); interpolationScheme cell; //cell cellPoint cellPointFace surfaces ( RUBLADE { type patch; patchName RUBLADE; // interpolate false; // needsUpdate true; } RUHUB { type patch; patchName RUHUB; // interpolate false; // needsUpdate true; } ); } ); |
October 9, 2015, 06:32 |
M. Montero
Rep Power: 17 |
I have repeated the post. Excuse me. I did not remember it.
Any idea how can it be done? |
October 9, 2015, 08:58 |
Solved
M. Montero
Rep Power: 17 |
For any person interested in this topic.
It is needed to change: File SampledPatch.C Line 145 false => true File SampledPlane.C Line 165 false => true Then using vtkAnim.py, available in the wikki, and paraview you can obtain quite beautiful movies. I have only revised patches and planes because it is my need currently. In this way, always always the patch is kept as updateable Best Regards |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
Problem with implicit unsteady solver | CCMuser | STAR-CCM+ | 2 | March 3, 2010 12:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
