June 3, 2015, 06:55 |
reconstructPar and reconstructParMesh
Londo
Rep Power: 11 |
Hello all
I am trying to reconstruct a case that I ran in parallel. If I run just "reconstructPar" it runs, but it return rubbish - the reconstructed case produces some weird results, and it can be seen that the reconstruction was not done in a proper way. So I tried to run "reconstructParMesh" and then "reconstructPar". In this case I am getting the following error when I am trying to run reconstructPar: Code:
Reconstructing volVectorFields U Reconstructing point fields --> FOAM FATAL ERROR: Incomplete patch point addressing From function pointFieldReconstructor::pointFieldReconstructor( const pointMesh& mesh, const PtrList<pointMesh>& procMeshes, const PtrList<labelIOList>& pointProcAddressing, const PtrList<labelIOList>& boundaryProcAddressing ) in file pointFieldReconstructor.C at line 96. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::pointFieldReconstructor::pointFieldReconstructor(Foam::pointMesh const&, Foam::PtrList<Foam::pointMesh> const&, Foam::PtrList<Foam::IOList<int> > const&, Foam::PtrList<Foam::IOList<int> > const&) at ??:? #3 at ??:? #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 at ??:? Aborted (core dumped) |
June 3, 2015, 07:31 |
Alex
Rep Power: 22 |
Can you please let us know how you decomposed the case? If you ran an Allrun script, can you post it here so that we can have a better knowledge about your case?
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
June 3, 2015, 11:00 |
Londo
Rep Power: 11 |
First I run decomposePar. I run it with 4 subdomains, hierarchical method, n (4 1 1). Then I run renumberMesh. After that I run the solver using mpi run and 4 processors.
December 6, 2015, 21:24 |
Fengjiao Bian
Rep Power: 12 |
Hi,Londo! I meet the same problem,the provious processes seems to be ok with no error and warning.Did you solver this problem?
March 20, 2018, 08:23 |
Same Error
Shafik Walakaka
Rep Power: 9 |
Anyone solved this issue yet?
I am receiving the same error and my blockmeshDict and my decomposeParDict is attached below. BlockMeshDict ************************************************** ********************************* /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 0) //point 0 (20000 0 0) //point 1 (20000 39.8101 0) //point 2 (0 39.8101 0) //point 3 (0 0 39.8101) //point 4 (20000 0 39.8101) //point 5 (20000 39.8101 39.8101) //point 6 (0 39.8101 39.8101) //point 7 (0 11.066 11.066) //point 8 (20000 11.066 11.066) //point 9 (20000 28.744 11.066) //point 10 (0 28.744 11.066) //point 11 (0 11.066 28.744) //point 12 (20000 11.066 28.744) //point 13 (20000 28.744 28.744) //point 14 (0 28.744 28.744) //point 15 (0 2.82843 2.82843) //point 16 (20000 2.82843 2.82843) //point 17 (20000 36.9817 2.82843) //point 18 (0 36.9817 2.82843) //point 19 (0 2.82843 36.9817) //point 20 (20000 2.82843 36.9817) //point 21 (20000 36.9817 36.9817) //point 22 (0 36.9817 36.9817) //point 23 ); blocks ( hex (20 21 22 23 4 5 6 7) (700 15 1) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 0 (top, outside) hex (16 17 21 20 0 1 5 4) (700 15 1) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 1 (right, outside) hex (23 22 18 19 7 6 2 3) (700 15 1) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 2 (left, outside) hex (19 18 17 16 3 2 1 0) (700 15 1) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 3 (bottom, outside) hex (8 9 10 11 12 13 14 15) (700 15 15) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 4 (middle) hex (12 13 14 15 20 21 22 23) (700 15 15) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 5 (top,inside) hex (8 9 13 12 16 17 21 20) (700 15 15) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 6 (right, inside) hex (15 14 10 11 23 22 18 19) (700 15 15) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 7 (left, inside) hex (11 10 9 8 19 18 17 16) (700 15 15) simpleGrading ( ( (0.2 0.65 1) //20% xdir 65%cells expansion=1 (0.8 0.35 10) //80% xdir 35cells expansion=10 ) 1 1) //block 8 (bottom inside) ); edges ( arc 0 4 (0 -8.245 19.905) arc 3 7 (0 48.055 19.905) arc 0 3 (0 19.905 -8.245) arc 4 7 (0 19.905 48.055) arc 1 5 (20000 -8.245 19.905) arc 2 6 (20000 48.055 19.905) arc 1 2 (20000 19.905 -8.245) arc 5 6 (20000 19.905 48.055) arc 16 20 (0 -4.245 19.905) arc 19 23 (0 44.055 19.905) arc 16 19 (0 19.905 -4.245) arc 20 23 (0 19.905 44.055) arc 17 21 (20000 -4.245 19.905) arc 18 22 (20000 44.055 19.905) arc 17 18 (20000 19.905 -4.245) arc 21 22 (20000 19.905 44.055) ); boundary ( inlet //patch name { type patch; //patch 0 faces ( (8 12 15 11) //inlet middle block face (12 20 23 15) //top block face, inner (20 4 7 23) //top outer block face (16 20 12 8) // right block face, innter (0 4 20 16) // right block face, outer (11 15 23 19) // left block face, inner (19 23 7 3) // left block face, outer (16 8 11 19) // bottom block face, inner (0 16 19 3) // bottom block face, outer ); } outlet { type patch; faces ( (10 14 13 9) //outlet block face, middle (14 22 21 13) //top block face, inner (22 6 5 21) //top block face outer (9 13 21 17) //right block face inner (17 21 5 1) //right block face outer (18 22 14 10) // left block face inner (2 6 22 18) // left block face outer (10 9 17 18) //bottom block face, inner (18 17 1 2) // bottom face, outer ); } walls { type wall; faces ( (0 3 2 1) (0 1 5 4) (3 7 6 2) (4 5 6 7) ); } ); // ************************************************** *********************** // DecomposeParDict ************************************************** ***************************************** /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 16; method simple; simpleCoeffs { n (4 2 2); delta 0.001; } hierarchicalCoeffs { n (1 1 1); delta 0.001; order xyz; } manualCoeffs { dataFile ""; } distributed no; roots ( ); // ************************************************** *********************** // Regards Shafik |
reconstructPar Fails - Not implemented From function slicedFvPatchField | carowjp | OpenFOAM Post-Processing | 3 | March 12, 2016 16:25 |
Problems with reconstructParMesh and reconstructPar in 15 | eberberovic | OpenFOAM Post-Processing | 27 | August 31, 2013 13:55 |
reconstructPar for time in dynamic mesh | kedarj14 | OpenFOAM | 3 | June 21, 2011 08:32 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
reconstructpar -region | borrbyper | OpenFOAM Bugs | 2 | April 23, 2009 14:52 |
