finding average values for a plane in the vertical direction |
March 10, 2013, 08:55 |
Nick Gutschow
Rep Power: 13 |
Hi Folks,
I have a finished run that looks good, paraView is showing expected behavior, but now I wish to create some plots for my data that paraView won't do. Specifically, I want to take some scalar, let's say T, and average it on a given horizontal plane. So let's say z is vertical and x and y go from 0 to 10; I want to average the T values for all 100 volumes (spread through my x-y plane) at a given z value. Then, I want to end up with results that I can use to plot z vs T in a conventional Cartesian manner. When I investigate my T file for some time step however, there is just a huge list of values. A given value is not explicitly tagged with a given x,y,z value in that file. So, my questions are as follows I guess: 1) Is anyone aware of good way to accomplish my go to produce data for my z vs T plot? 2) If not, looking ahead to making my own function, where is it referenced what index in a given scalar file at a given timestep corresponds to a given spatial location? Or, is there a trick to output or export OpenFOAM data in a more readable and manipulable format to my end? Thanks everyone! -NG |
March 13, 2013, 19:46 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
bins=numpy.linspace(min(minY),max(maxY),25) vol,edges=numpy.histogram(heightField,bins=bins,weights=volume) alpha,edges=numpy.histogram(heightField,bins=bins,weights=volume*alphaField) xVals=0.5*(edges[1:]+edges[0:-1]) vals=alpha/vol data=numpy.asarray([xVals,vals]).T numpy.savetxt(dataFile("alphaByHeight"),data) - This is for alpha1 not for T - for height Y not Z - You'll probably have to import numpy - This was lifted from an example of swak4Foam (fillingTheDam) and the variables minY, maxY, heightField (which is Y), volume (the cell volumes), and alphaField reach the python-namespace through some swak-Stuff (this is from a function-object that evaluates this python-code at each write-time). I must admit I haven't done much python in Paraview recently so I can't tell you how to best get to the data (with the "Python Calculator", "Programmable Filter" or by working on the Python Shell) but if you get to a solution I think it would be much appreciated if you shared it here
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 15, 2013, 10:16 |
Nick Gutschow
Rep Power: 13 |
gschaider,
Thanks for the reply! I have got to say however, there MUST be an easier way. Actually, this is driving me a bit nuts now. Using the sample utility I am able to produce a 1d line of data using the "raw format for sets as follows: 1 1 1 300 2 1 1 301 3 1 1 302 Where that is x, y, z, and T for temperature say. But I can only vary one of the x, y or, z values I guess? I want an output just like this, but I want it to just pump out the T value for every cell, not just the cells in a single line. I find it hard to believe that this functionality does not exist in this utility. It seems so basic... The most basic of outputs; just a text file giving (x y z <field 1> <field 2> <field 3>....) in columns. Does anyone know if and how the sample utility could be used to do this? -Nick |
March 15, 2013, 11:18 |
Nick Gutschow
Rep Power: 13 |
Ok, I think I found my own work around.
From paraView I can just save my data as a csv, which outputs all my fields and points. From here I am half way through a MATLAB code to basically area weight average the scalar in question for a given plane and then set these to vertical displacement values equal to the center point of that plane. -NG |
March 15, 2013, 15:56 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
That is the nice thing about people: that they have different views what is "easy" and each of these ideas is valid: for you the idea of clicking through two different programs and letting them "communicate" through files, for me to invest some work in the beginning and then just starting the run and have all the data ready for me when it is finished (of course your way is more time efficient if you only have to do this once for one run)
March 15, 2013, 16:02 |
Nick Gutschow
Rep Power: 13 |
Indeed. It is really just me shying away from Python for lack of experience. Thanks again for the input.
-NG |
March 18, 2013, 23:06 |
#7 | |
Albert Tong
Rep Power: 15 |
I would like to choose part of a patch (for instance, cylinder faces in a specific domain), and then calculated the forces on this selected part. Is there a way to do this in OpenFoam at run-time? Thanks a lot, Albert |
March 19, 2013, 06:31 |
#8 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If you're going for complete patches you might look into the forces-functionObject that comes with OF. If you only want to select parts of the patches then you can use for instance a swak-patch expression that looks like this: Code:
the Forces { type patchExpression; patches ( wall1 wall2 ); variables ( "radius=0.1;" "forces= .... ;" // that is the part you have to specify ); expression "(sqrt(pos().x*pos().x+pos().y*pos().y)<radius) ? forces : vector(0,0,0)"; accumulations ( sum ); }
March 19, 2013, 10:43 |
#9 | |
Albert Tong
Rep Power: 15 |
For pressure force, the expression is simple, Code:
"forces= p*sf()*mag(sf()) ;" Code:
"forces= rho()*nu*dev(twoSymm(grad(U))) *sf()*mag(sf());" Regards, Albert |
March 19, 2013, 11:16 |
#10 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
For your expression: would have to look it up myself how the original functionObjects calculate that. But what might be sufficient to reformulate it in terms of snGrad(U) (that is available in groovyBC). Otherwise you'd have to use an expressionField-functionObject that creates a field named devGradU with the expression "dev(twoSymm(grad(U)))" and use that field in your expression (not sure but you might have to use internalField(devGradU) if that field is 0 on the boundary). Also: rho is a field. So no (). nu depends on the solver whether this is available as a field (only then swak can access it. There are ways to get it anyway)
March 25, 2013, 03:44 |
#11 | |
Albert Tong
Rep Power: 15 |
Many thanks for your help. The final expression is Code:
p*rho*normal()*area()-rho*nu*snGrad(U)*area() BTW, what is the difference between sf() and area() ? Regards, Albert |
March 25, 2013, 06:55 |
#12 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Co...Usage_examples Basically "Sf()" is "area()*normal()" (for OpenFOAM that describes all it needs to know about that face in a single value)
March 25, 2013, 11:24 |
#13 | |
Albert Tong
Rep Power: 15 |
Thanks. Just let you know the wiki-page has been updated to include this usage. Kind regards, Albert |
March 25, 2013, 12:22 |
#14 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Just saw it. Great
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
finding average temperature of room | sunilpatil | CFX | 1 | February 3, 2013 06:03 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
Finding Average Temperature and Solid Fraction | atulverma | FLOW-3D | 1 | May 14, 2009 13:39 |
Finding average x-velocity at any particular x. | Dpu | FLUENT | 2 | April 11, 2006 23:32 |
