[snappyHexMesh] meshing with snappy: im a very beginner |
February 22, 2010, 21:34 |
water flow into a tank in 3D
#21 |
sesha
Rep Power: 17 |
I want to create a 3D mesh Last edited by hamsadhwani8; February 23, 2010 at 08:32. |
August 4, 2010, 22:27 |
#22 |
Lee
Rep Power: 16 |
I am newbie in OPENFOAM too. While I run the execution with snappyHexMesh, it is fatal error,
cnlee@cnlee-desktop:~/OpenFOAM/cnlee-1.7.0/run/tutorials/mesh/snappyHexMesh/motorBike$ snappyHexMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-279cc8e8233b Exec : snappyHexMesh Date : Aug 05 2010 Time : 09:26:16 Host : cnlee-desktop PID : 2511 Case : /home/cnlee/OpenFOAM/cnlee-1.7.0/run/tutorials/incompressible/simpleFoam/motorBike nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL IO ERROR: cannot open file file: /home/cnlee/OpenFOAM/cnlee-1.7.0/run/tutorials/incompressible/simpleFoam/motorBike/system/fvSolution at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. FOAM exiting Anyone know what is my OpenFoam problem? Btw, I using OpenFOAM 1.7 Regards Lee |
August 5, 2010, 05:54 |
#23 |
Philip Cardiff
Rep Power: 34 |
Hi Lee,
snappyHexMesh cannot find the fvSolution file, did you copy the motorbike case directly from $FOAM_TUTORIALS without making any changes to it? There should be a fvSolution file in the system folder in the motorbike case? Is this file (motorbike/system/fvSolution) there? Philip |
August 5, 2010, 22:22 |
#24 |
Lee
Rep Power: 16 |
Hi Philip,
It works for me now. Thanks a lot! May I ask you another question? If I want to do a snappyHexMesh for other stl file, what file need to make a change? Sorry, I am a newbie in OpenFOAM. Regards Lee |
August 8, 2010, 10:52 |
#25 |
Philip Cardiff
Rep Power: 34 |
Lee,
You can put your stl file (I think it should be a ASCII stl) in the "constant/triSurface" directory. You then need to open the "system/snappyHexMeshDict" file and find where the stl file is specified and change motorbike.stl to the name of your stl. You have to create your background mesh some how too, usually with blockMesh. It is all explained well in the User Guide: http://www.openfoam.com/docs/user/snappyHexMesh.php Philip C |
August 27, 2010, 02:35 |
Error during snappyHexMesh
#26 |
hc
Rep Power: 16 |
Hi all,
(Motorbike) I have no problem executing the blockMesh command. Then I execute, snappyHexMesh, the errors show below. It's freshly install openfoam. (ubuntu 9.10, OF 1.6.) /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-53b7f692aa41 Exec : snappyHexMesh Date : Aug 27 2010 Time : 13:19:42 Host : orange PID : 2674 Case : /home/orange/OpenFOAM/orange-1.6/run/tutorials/incompressible/simpleFoam/motorBike nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 500 Read mesh in = 0.04 s Overall mesh bounding box : (-5 -4 0) (15 4 8) Relative tolerance : 1e-06 Absolute matching distance : 2.29783e-05 Reading refinement surfaces. Read refinement surfaces in = 3.06 s Reading refinement shells. Refinement level 4 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0.03 s Determining initial surface intersections ----------------------------------------- #0 Foam::error:rintStack(Foam::Ostream&) in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam:rimitiveMesh::cellEdges(int, Foam:ynamicList<int, 0u, 2u, 1u>&) const in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam:rimitiveMesh::cellEdges(int) const in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::hexRef8::getLevel0EdgeLength() const in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdynamicMesh.so" #6 Foam::hexRef8::hexRef8(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdynamicMesh.so" #7 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/home/orange/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so" #8 main in "/home/orange/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/snappyHexMesh" #9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #10 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Segmentation fault Any idea, what went wrong? Thank you so much. watashiwa newbie |
August 27, 2010, 07:14 |
#27 |
Philip Cardiff
Rep Power: 34 |
Hi watashiwa,
I am not sure what is causing your error, maybe someone else here has a better idea, but did you just install OpenFOAM or did you compile it too? If you compiled it then I would recommend to try re-compiling snappyHexMesh: Code:
cd $FOAM_UTILITIES/mesh/generation/snappyHexMesh wclean wmake Code:
cd $FOAM_SRC wmake libso OpenFOAM wmake libso dynamicMesh BUT it might be over-kill compiling OpenFOAM,maybe someone else has an easier solution. Philip |
August 27, 2010, 11:59 |
#28 |
hc
Rep Power: 16 |
Hi Phil,
I have just tried that out, same problem. No idea, what's wrong. what do you think if I replace the stl file which is related to my research, will snappyHexMesh solver is affected due to this error? I reckon installation should be no problem since I can use solidDisplacementFoam without any problem. Hmm... Anyway I will try that out by replacing my stl file and see how it goes. I hope someone can come out with this solution. Thank you so much. watashiwa is sad |
September 10, 2010, 07:42 |
#29 |
Jitao Liu
Rep Power: 17 |
Dear all.
Can snappyHexMesh generate meshes for the inner region of the triangulated surface geometries in Stereolithography (STL) format ? |
September 10, 2010, 07:46 |
#30 |
Philip Cardiff
Rep Power: 34 |
September 11, 2010, 07:25 |
#31 |
Jitao Liu
Rep Power: 17 |
Hi Philip ,
Thanks for your reply. As you suggested, internal meshes for the STL geometry can be generated by seting the locationInMesh in the snappyHexMesh dictionary to be inside the STL geometry. But there is only one patch named as the wall of the STL geometry. My question is that how to seperate this patch into different patches (as noted in the enclosed picture ) ? Eugene suggested use separate STL surfaces for each region. http://www.cfd-online.com/Forums/ope...pyhexmesh.html And I do split my STL surfaces into three seperate regions : inlet, runner and cavity and get three STL files : "inlet.stl", "runner.stl" and "cavity.stl". The corresponding patches are defined in the STL file as follows:
solid inlet
The following methods are used:
Any suggestions will be highly appreciated. Jitao |
September 13, 2010, 02:14 |
#32 |
"My question is that how to seperate this patch into different patches (as noted in the enclosed picture ) ?" After the mesh generation (using snappyHexMesh) is complete you might want to use the > autoPatch utility for obtaining patches based on feature angle. I have not used it though. "However only one part of the three seperated regions can be meshed. It depends on where the point of locationInMesh is defined. " The only reason for this (as far as I know) is due to the individual stl's being closed. "Is it possible to define numbers of locationInMesh points in the snappyHexMesh dictionary ? " Though I am not the right person to answer this question; but then defining multiple points as locationInMesh is not available in snappyHexMesh. Suggestions: run > surfaceCheck on the individual stl files - to see if they are closed geometries. And we don't want them to be closed. The combined stl though needs to be closed geometry, if you wish to have a mesh inside the enclosed surface. Hope it helps ! |
September 13, 2010, 05:46 |
#33 | ||
Philip Cardiff
Rep Power: 34 |
There is also a GUI tool called patchTool which was in OpenFOAM-1.4 where you could pick individual faces and add them to a patch, but I don't think there is any similar utility in the current version - you could try install the old version but the mesh formats are slightly different so this seems like a lot of work. Quote:
Hope it helps, Philip |
September 13, 2010, 12:55 |
#34 |
Rep Power: 17 |
Awacs,
If all your stl files are enclosed in the blockMesh outer domain and your reference location point is well positioned then there should not be any problem. To be on the safe side I usually place the location point just inside one of the outer corners of the domain. Now for having different patch names, just edit the individual stl files and add the patch name after the word solid which occurs at the very top of the stl file, and the word endsolid which occurs at the very bottom of the stl file. You also have to define the patch names as regions in the snappyHexMeshDict geometry section. Then you should use these patch names directly in the addLayersControls section. However, in the refinementSurfaces sections stick to the stl file name as defined in the geometry section. See the example below for the stl file of a geometry section from stl file Terrace.stl, called Terrace, and associated to patch name TERRACE. ASCII stl file Terrace.stl: Code:
solid TERRACE facet normal 0.000000e+00 1.000000e+00 -0.000000e+00 outer loop vertex 3.600000e+00 3.950000e+00 1.670000e+01 . . . vertex 3.600000e+00 3.950000e+00 1.670000e+01 endloop endfacet endsolid TERRACE Code:
Terrace.stl { type triSurfaceMesh; name Terrace; regions { TERRACE { name TERRACE; } } } Code:
Terrace { level (2 2); } Code:
TERRACE { nSurfaceLayers 1; } Ziad |
September 15, 2010, 22:35 |
#35 |
Jitao Liu
Rep Power: 17 |
Many thanks to Amol, Philip and Ziad. I will try it out and feed back soon. |
August 24, 2011, 12:37 |
#36 |
Rep Power: 15 |
Hello, I'm also a beginner with paraFoam, and here is my (stupid) problem :
I'm on the motorbike case, and when I create the castellated mesh, I don't know how to display it on paraview. When I open paraview, and tape I want to open the log.castellated file, it tells me : " A reader for "/home/my_name/OpenFOAM/my_name-1.7.1/run/tutorials/incompressible/simpleFoam/motorBike could not be found, please choose one : " and I have a list of programs I have to choose. Do you know what to do?? Thx a lot! |
August 25, 2011, 08:28 |
#37 | |
Roman Thiele
Rep Power: 21 |
~roman |
November 29, 2011, 05:51 |
#38 |
Rik
Sorry, my post is now totally off topic. My reply was a response to a message from 2009. Didn`t notice the date
If you want to use paraFoam to see time step 3 you can do the following: 1) Make sure your terminal is in the main directory of the motorBike case ../motorbike. 2) run paraFoam 3) if paraFoam opens correctly, use the buttons at the top to go to time step 3. The buttons look like -> http://images.wikia.com/scivis/image...e_controls.png It now should visualize timestep 3 and if your case ran correctly, time step three gives the fully castellated and snapped motorbike. So for clarity, don`t run paraFoam from inside the folder named 3, just run it in the main folder and use the timecontroles inside paraView to change what you are looking at. |
[snappyHexMesh] snappyHexMesh stops meshing | Tensian | OpenFOAM Meshing & Mesh Conversion | 2 | January 26, 2014 10:54 |
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? | pipolaki | ANSYS | 0 | December 6, 2013 09:12 |
[snappyHexMesh] Meshing NACA airFoil with snappy | Paolo.F | OpenFOAM Meshing & Mesh Conversion | 6 | October 8, 2013 05:52 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 06:01 |
