March 3, 2008, 11:33 |
Axisymmetric cylindrical meshes
Jësús Garicano
Rep Power: 17 |
Greetings to you all!
I'm new with OpenFOAM. I need to model an axisymmetric cylindrical problem (very similarj to a Burke-Schumann configuration) but in2D. Could any of you send me a Block Mesh dictionary in which appears the definition of an axisymmetric cylindrical geometry but treated as an 2D problem? Thanks in advance. |
March 3, 2008, 11:55 |
Hi Jesus,
I'm not sure I un
Michael Jaworski
Rep Power: 17 |
Hi Jesus,
I'm not sure I understand your problem. Do you want to build a 2D axisymmetric mesh and need an example, or are you trying to approximate axisymmetry with a cartesian coordinate mesh? If you want to use an axisymmetric mesh for your case, the icoDyMFoam tutorial "moving cone" has such a mesh generated with the blockMesh utility. Good Luck, Mike J. |
March 4, 2008, 09:12 |
Hi Michael:
I've started mo
Jësús Garicano
Rep Power: 17 |
Hi Michael:
I've started modifying the geometry related to the lesInterFoam tutorial in order to get a longitudinal section of an arrangement of two coaxial tubes (the inner one being shorter than the outer one). This intends to be a 2D model of a combustion chamber. I've developed the blockMeshDictionary but when running blockMesh I get the following: Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty --> FOAM FATAL ERROR : Trying to specify a boundary face 4(2 8 30 25) on the face on cell 3 which is either an internal face or already belongs to some other patch. This is face 0 of patch 4 named separatingWall.#0 Foam::error::printStack(Foam:stream&) in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/blockM esh" #4 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/blockM esh" #5 main in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/blockM esh" #6 __libc_start_main in "/lib/libc.so.6" #7 Foam::regIOobject::readIfModified() in "/home/jgaricano/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/blockM esh" The problem is in the nonzero width wall of the inner tube. Thanks in advanced for your interest. |
March 4, 2008, 14:12 |
I don't think I've seen that p
Michael Jaworski
Rep Power: 17 |
I don't think I've seen that particular error before. If you've never used blockMesh before, I think the biggest hurdle is making sure your vertices are defined in the correct order for both the patches and the blocks. There's information in the user manual which has all the "rules" for doing so. You may need to check that the patches all have their face-normals pointing away from the computational domain.
Good luck, Mike J. |
March 4, 2008, 15:07 |
Sometimes it helps to visualis
Mattijs Janssens
Rep Power: 26 |
Sometimes it helps to visualise the points. blockMesh with -blockTopology option will dump an .obj file which can be viewed in e.g. javaview or paraview (using objToVTK).
March 4, 2008, 15:11 |
Thanks a lot for your interest
Jësús Garicano
Rep Power: 17 |
Thanks a lot for your interest. Fortunately I've been able to solve the problem. It was a mistaken space. I'm very sorry of having troubled you.
See you. |
Axisymmetric solution of a 3D cylindrical domain | cfdstar | FLUENT | 3 | December 24, 2017 03:30 |
NS eq: 3D unsteady compressible to axisymmetric cylindrical 2D laminar+incompressible | rere | Main CFD Forum | 7 | November 28, 2015 05:53 |
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? | shubiaohewan | Main CFD Forum | 10 | May 2, 2013 15:08 |
Derived planes for axisymmetric planar meshes | jonny_b | STAR-CCM+ | 0 | August 12, 2010 11:22 |
using RSM with axisymmetric meshes? | mystic_cfd | FLUENT | 0 | January 14, 2004 09:17 |
