[Netgen] Netgen and surfacecheck
Old   March 26, 2008, 05:39
Default Netgen and surfacecheck
Mark Couwenberg
markc is on a distinguished road
L.S.,
Can anyone explain me how to use the tool surfaceCheck? Do I have to compile it first? And how?
I have a geometry which is very hard to mesh in Salome, using Netgen. Allthough the build-in geometry checks in Salome say that everything is fine, meshing fails all the time.
If anyone is willing to check my files, I can send them. It don't manage to copy them in this post.
Mark
markc is offline   Reply With Quote
Old   March 27, 2008, 16:43
Default surfaceCheck is in the standar
Mattijs Janssens
mattijs is on a distinguished road
surfaceCheck is in the standard release. The things to check for is that your surface is manifold/closed (i.e. every edge has two faces). Netgen has problems if your cell size is bigger than the feature size. Try meshing with more tets.
mattijs is offline   Reply With Quote
[Netgen] Netgen .stl file import - segmentation fault Artur OpenFOAM Meshing & Mesh Conversion 0 May 19, 2013 16:14
[Commercial meshers] Harpoon to Foam Manuel Garcia (Garcia) OpenFOAM Meshing & Mesh Conversion 58 March 25, 2008 19:38
[Netgen] Import stl file netgen writes segmentation faulterror unoder OpenFOAM Meshing & Mesh Conversion 8 October 2, 2005 11:26
