[mesh manipulation] dynamic meshing has continuity error
Old   October 24, 2024, 07:21
Default dynamic meshing has continuity error
ann liu
ann liu is on a distinguished road
Hello Dear Foamers,
I am using openfoam v10 compressibleinterfoam to build up dynamic meshing based on alpha.water field.
(1)
Based on the dambreak tutorial, I made it to be a 3D case, with all boundaries closed wall.
When I run the case with dynamic meshing it says timestep continuity error (as the picture 1), but the code can still continue to run. (The dynamicmeshdict file is as attached)
(2)
I also tried to build a case with compressibleinterfoam where water enters a tank through inlet patch. The tank is initially filled with air, and has no venting. When I apply dynamic meshing, it shows a continuity error (attached as picture 2) and stops running.
Tested solutions:
1. To solve this continuity error, I tried different refinement fields, different inlet conditions, different correctfluxes, they all did not work.
2. I tried a 3D dambreak case with all closed wall, and run it with openfoam v11, there is no continuity error.
3. I tried the 3D dambreak case (with one patch open and connected with atmosphere), and run it with openfoam v11. When there is dynamicmeshing the code says core dumped.
In your opinion, what might be the problem, and what should I try to remove the continuity error?
Thanks again for your help !
Best,
Ann
ann liu is offline   Reply With Quote
compressibleinterfoam, dynamicmesh error
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
