[Other] Help with mesh failing and auto (topological) remeshing |
April 28, 2021, 23:47 |
TWB
Rep Power: 19 |
I'm trying to simulate a flow past moving wing. I create my own routine to move the wing. The simulation works fine until around 0.44s, whereby it diverges. Mesh check shows that the mesh quality starts to drop from t=0.4. Since I need to run till t=1, I need to ensure the mesh quality does not drop. I have tried to: 1. reduce time step 2. change different meshing but it doesn't help. I saw a video on youtube by wolf dynamics: https://www.youtube.com/watch?v=QEGnNLvQVfA&t=1047s At runtime 19.02: They use body fitted mesh with re-meshing. How is this done? Is it possible to automatically re-meshing the entire domain when the mesh quality drops below a certain level? Or can I do it manually? So maybe at t=0.4 when the mesh quality is dropping, I stop the simulation, re-mesh, copy data to new mesh, and continue running. Is it possible? Thanks in advance. |
