April 22, 2021, 14:23 |
Cells not attached
Rep Power: 5 |
I am trying to mesh a geometry in SHM and I cannot get the volume mesh to attach to the edge...see image attached. Why is that? Thanks |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone | Siegunn | OpenFOAM Meshing & Mesh Conversion | 4 | July 31, 2015 05:10 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
