[mesh manipulation] StitchMesh creates non-orthogonal cells
Old   March 22, 2017, 07:08
Default StitchMesh creates non-orthogonal cells
Roger
Coenstra is on a distinguished road
Dear users,
I am trying to stitch 2 parts of a mesh together. Both parts are created with hyperbolic extrusion and then converted to foam from a P3D -file. For the stitching i created a faceSet with topoSet and then a patch with createPatch. Until here, everything is well.
However when i use stitchmesh on the patches it gives a non-orthogonality of 87. When one looks at the mesh itself you see that the cells perfectly align. (see attached) Another part of the patches is stitched together correctly. Can anyone help me why this happens, or if there are other tools that can do this? I have tried to mess around with a toleranceDict but this does not seem to work.
Kind regards, Roger
Coenstra is offline   Reply With Quote
Old   October 4, 2017, 13:15
Thomas Evans
windscion is on a distinguished road
Orthogonality (in OpenFOAM, specifically checkMesh) is strictly a relation between cells. Specifically, it is the angle between the face vector and the cell center to cell center vector. Cells, therefore, have no orthogonality measure in themselves.
ignore >> At the inside corner, your cell center to cell center vector is nearly vertical, but the face vectors nearly horizontal. Hence the bad orthogonality result. << ignore
Okay, I didn't look closely enough. Thought I was looking at a 2d mesh, not part of a 3d mesh. Can't tell where/how stitched, but that should be where the cells don't line up well.
Also, the cells which connect may not be the obvious ones. If the cells are ever-so-slightly offset, there may be new faces created between cells that do not look connected.
windscion is offline   Reply With Quote
non orthogonal, stitchmesh
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 12:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Proam creates negative extrusion cells if away from origin cfdengineer STAR-CD 1 January 27, 2011 06:02
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
