[Commercial meshers] Importing 3D Fluent Mesh file into OpenFOAM Error
Old   December 20, 2016, 13:00
Default Importing 3D Fluent Mesh file into OpenFOAM Error
Sam
SamEngD is on a distinguished road
Hello CFD online community,
I am fairly new to OpenFoam and posting online for help, so please forgive me if this is not asked in the correct thread or has been covered before.
I am trying to take the 3D geometry from the pipe tutorial in Fluent and import it into OpenFoam to perform the simulation in 3D. I have set up the geometry and saved it as a .msh ASCII file. I was not sure how many named sections were required so I named all external faces.
Inlet velocity (small and large)
Pressure Outlet
Symmetry... and...
The outer half of the pipe.
When I run fluent3DMeshToFoam the boundary conditions appear fine and I adapted the 2D elbow tutorial in OpenFoam and it runs, but the Courant number increases and I get the errors below with (core dumped).
If anyone could tell me where I can find out how to create the geometry correctly in ANSYS to import into OpenFoam or whether that is correct but I am doing something else wrong that would be a great help.
Thanks in advance
Sam
Courant Number mean: 92.1761 max: 6992.39
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? in "/home/sam/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#7 ? in "/home/sam/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#8 ? in "/home/sam/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#9 ? in "/home/sam/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/home/sam/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam"
Floating point exception (core dumped)
SamEngD is offline   Reply With Quote
Old   January 3, 2017, 04:47
Marvin
Flukato is on a distinguished road
If the Mesh is the Problem you should check the differences between the two checkMesh log files
Flukato is offline   Reply With Quote
Old   January 19, 2017, 11:55
Sam
Hi Marvin thanks for your reply, I have since removed the error by significantly reducing the deltaT in the ControlDict file. However I am still not gaining matching results to Fluent and the contours do not look quite right. The example in OpenFoam is 2D and the geometry I am trying to work with is 3D from the ANSYS tutorial, would you know the correct way to set this up?
ansys fluent 17.2, openfoam 1606+
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
