August 17, 2016, 13:21 |
snappyHexMesh 3D
Mehdi
Rep Power: 10 |
hello everyone i m simulating an 3D airfoil and the mesh isn't fine after using snappyHexMesh that's what we see on paraview:
thank you for answering me best begards |
August 17, 2016, 15:50 |
Daniel P. Combest
Either increase the refinement levels on the airfoil surface or make your base mesh size smaller. Your local cell size is too large for the snapping to happen accurately. You also might want to extract your feature edges into an eMesh and turn on explicit feature edge detection. Good luck.
August 20, 2016, 09:36 |
Mehdi
Rep Power: 10 |
thank u for replaying Dan
i diid whatt u suggested to do but nor good résults, i m still trying now. |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
