[blockMesh] Strange non-hexahedral cells?
Old   May 17, 2016, 09:35
Default Strange non-hexahedral cells?
maka15 is on a distinguished road
I'm quite new to openfoam and I am seeing a strange behavior on a very simple blockMesh I want to use for snappyHexMesh..
It is just a cuboid with cube-cells, but when I view the Mesh with paraView, I see very strange cells, that I can't explain. I only see them in the middle of the block in the XZ-Plane. Attached you find an image of ParaView showing these strange cells, if you want to reconstruct using the Dicts below, create a slice in ParaView, click "Y normal" and don't move the plane...
Would be nice, if someone here has an idea, what I am doing wrong..
Thanks a lot for your help!
system/blockMeshDict
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object blockMeshDict;
    convertToMeters 1;
    vertices
      ( -0.02 -0.02 -0.032)
      ( 0.02 -0.02 -0.032)
      ( 0.02 0.02 -0.032)
      ( -0.02 0.02 -0.032)
      ( -0.02 -0.02 0.013)
      ( 0.02 -0.02 0.013)
      ( 0.02 0.02 0.013)
      ( -0.02 0.02 0.013)
    blocks
      hex ( 0 1 2 3 4 5 6 7) ( 80 80 90)
      simpleGrading ( 1 1 1)
    edges
    patches
    mergePatchPairs
system/controlDict
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object controlDict;
    startFrom startTime;
    startTime 0;
    stopAt endTime;
    endTime 1000.0;
    deltaT 1.0;
    writeControl timeStep;
    writeInterval 1000.0;
    purgeWrite 0;
    writeFormat ascii;
    writePrecision 100;
    writeCompression uncompressed;
    timeFormat general;
    timePrecision 6;
    graphFormat raw;
    runTimeModifiable yes;
system/fvSchemes (only so paraFoam does not warn about missing files..)
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object fvSchemes;
    divSchemes
    gradSchemes
    laplacianSchemes
system/fvSolution (only so paraFoam does not warn about missing files..)
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object fvSolution;
    solvers
maka15 is offline   Reply With Quote
Old   May 17, 2016, 10:16
Antimony is on a distinguished road
Do a checkMesh and see the type of cells that it reports. My guess is that it will still be hexes.
The reason you see the weird cells is because Paraview decomposes polyhedral cells automatically and when you take a slice, it triangulates the slice. Uncheck both options and you will see that they are regular hexes only.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   May 17, 2016, 11:17
thanks for your help, Antimony!
checkMesh reports only hexes, you are right.
If I uncheck decomposing and triangulating, it does look better, but still weird, see attached image.
@Mods: It seems, this is more likely a problem with paraView than with blockMesh, could you please move the thread to the right subforum?
Old   May 19, 2016, 09:56
Mikko
Flowkersma is on a distinguished road
Try using ExtractCellsByRegion filter when you want to visualize the mesh. If you want slice like behavior check Extract only intersected and Extract intersected marks. If you compare the results from ExtractCellsByRegion filter to the results of Slice filter, maybe you can find a reason for the "strange" behavior.
Regards,
Mikko
Flowkersma is offline   Reply With Quote
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
Strange cells in Trimmed mesh yatsh94 Siemens 0 February 28, 2017 18:40
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 21:32
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
7 Node Hexahedral Cells Mark FLUENT 0 February 5, 2007 12:10
